Build Advice HDD salvage
Discussion in 'Hardware' started by ninjaplease, 27 Jan 2012.
  1. ninjaplease
    ninjaplease I don't know what I'm doing
    11 Jan 2012
    Bit of background, I'm nearing the end of my first build (parts list in signature) and I decided to take a trip to the family home.
    While poking through all my old stuff, I came across an old laptop and an old 2.5" HDD.
    After an hour of removing miniature screws, I'm now the proud owner of one of these:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822146043
    and one of these:
    http://www.powersourceonline.com/buy-equipment/fujitsu-Parts/MHT2040AH/31776640-MHT2040AH-cy-en.jsa
    As I know very little general knowledge about connectors, I have no idea what cables to buy that will allow me to join these to my current beast (and add a whopping 120GB of 5400rpm glory).
    The first HDD has two rows of little pins (approx 2x24) then a small gap and four more little pins in a square.
    The second HDD has the same, however came fitted with some kind of adapter to a thin slot-type plug.
    Any help would be greatly appreciated.
  2. Tangster
    23 May 2009
    You'll need laptop IDE to IDE cables.
  3. ninjaplease
    11 Jan 2012
  4. Tangster
    23 May 2009
    That'll work as well.
  5. ninjaplease
    11 Jan 2012
    Thanks bro, I appreciate the effort.
