Build Advice hdd seems slow on new build
Discussion in 'Hardware' started by jakemorris3000, 20 Feb 2010.
  1. jakemorris3000
    jakemorris3000 What's a Dremel?
    12 Feb 2010
    hi guys,
    i have just finished putting together my new build i5 750 with giga byte GA-P55M-UD2 motherboard, i used my 2month old hdd (1TB Western Digital Caviar Black SATA II 7200rpm 32MB Cache) from my previous pc, the problem is the hdd seems slow- is there a bios setting i have missed out?
    regards
    jake
  2. mrbungle
    20 Sep 2004
    download hd tach and give us some figures
  3. GoodBytes
    20 Jan 2007
    Ensure that:
    • In Windows open device manager, then go to Disk Drive section, and double click on your HDD. On the panel that will appear, go to the policies tab, and make sure that the HDD is set to performance (may not see that option, if you don't that means the system knows it's an internal HDD so no worries), and that the check box Enable write caching... is enabled. Feel free to check also "Turn off Windows write-cache buffer" for more performance, but it is recommended to have some sort of battery system during any power surge, as the HDD can, by bad luck, corrupt some of the data. For me, I never had any problem.. but I might just be lucky. It fine on laptop's, as it has 2 power sources.
    • In the BIOS, make sure that your HDD controller is set to SATA mode (if it's AHCI then it's fine as well) - WARNING it might lead to have Windows not boot anymore. If this occurs restore back the setting, until you have time to reinstall Windows under SATA mode. Also, take your time to check out Gigabyte motherboard instruction manual (well done in my opinion), to make sure that that they are not additional settings that may be linked SATA controller/HDD performance.
    • Ensure that Windows is in Balance mode.
    • And that your disk is defragmented (I recommend O&O Defrag 12 64-bit - Enable Zones and do Optimize/Complete defrag (from the Start button) - This process can take sever hours for the first time, and I recommend doing it overnight.
    Guest-16 likes this.
  4. jakemorris3000
    12 Feb 2010
    thanks guys,here are my readouts from hd tach (long bench test),
    Burst speed- 2915.3 mb/s
    random access - 12.5 ms
    cpu utilization - 1%
    Average read 89.2 mb/s
    what do you reckon?
    thanks
    jake
  5. Guest-16
    Guest-16 Guest
    Average read is somewhat low.
    Did you follow the things that GoodBytes said? (+rep btw - awesome reply!)
    Also, try turning off SpeedStep, it slows the SATA performance :)
  6. Pookeyhead
    30 Jan 2004
    Really? Why is that?
  7. Guest-16
    Guest-16 Guest
    Because we found on recent Intel CPUs if the BIOS is not coded correctly, you can overclock the CPU or turn off speedstep and get a better SATA performance.
  8. Pookeyhead
    30 Jan 2004
    I'll try that. I'll be annoyed if it improves actually.. because I like having speedstep on, but will hate the thought of not getting max data transfers.
    Grrr.. there's always something!
  9. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Out of curiosity, why do you recommend this? I've always wondered what the difference was between the Balanced and High performance profiles (I just leave it on high performance because it sounds faster :lol:).
  10. Pookeyhead
    30 Jan 2004
    I forgot to ask that myself. Surely high performance mode will yield... well.. higher performance?
  11. Jux_Zeil
    Jux_Zeil What's a Dremel?
    30 Apr 2009
    It's more to do with the CPU throttling when idle than the data throughput.
  12. Guest-16
    Guest-16 Guest
  13. smc8788
    smc8788 Multimodder
    23 Apr 2009
    I beg to differ...
  14. GoodBytes
    20 Jan 2007
    Why not high performance? I thought you would enjoy a quieter computer.
    Balance mode, means "provide me maximum performance (CPU), but when my computer is idle, down-clock my system (and spin down/turn off the HDD after 16min (default I think), when I don't use my HDD) a bit to reduce heat, and save power". While high performance means "Keep my all my components in my system awake, and have my CPU at max speed no mater what".
    Their is no performance gain between Balance and High Performance mode.
    As long as it's not on PowerSaver, it's fine.
  15. GoodBytes
    20 Jan 2007
    Interesting, so it is best to get the latest BIOS, perhaps it has the issue fixed.
    Oh if your motherboard has a second SATA controller, like the SATA 6GB/s that Gigabyte's ahs added on select motherboards. plug it on there, it could avoid the mentioned problem.
  16. Pookeyhead
    30 Jan 2004
    Tested with Asus P6T Deluxe (latest BIOS)
    No discernable difference.
    Balanced Power profile, Speedstep ON - CPU speed during test 2400MHz
    Performance Power profile, Speedstep OFF, CPU speed during test 3800MHz
    Thank god for that! I'd hate to have to run full bore all the time to get best disk performance.
    No.. they are not the wrong way around.. it was slightly faster when in balanced mode. Obviously just minor differences between tests, and as I didn't run several to create an average, we can assume performance would be the same for both profiles if the tests were more exhaustive.
  17. GoodBytes
    20 Jan 2007
    The difference that you see is fine, if you execute the test another time, you'll get different but close to the same results.
    I don't know why exactly, but one can assume that if you have a background process or OS that does something with the HDD (like writing the cache onto the disk, indexing, etc..) it changes the results a little.
