Storage HDD space has vanished
Discussion in 'Tech Support' started by Margo Baggins, 22 Oct 2011.
  1. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    This is really baffling me, yesterday I had more than 100gb spare on my H: drive, now i dont.
    windirstat is still showing that i should, but the disk properties isnt, as far as i can see on the disk, there isnt stuff on there, and I certainly haven't added 100gig of stuff.
    Any ideas?
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Failing hard drive maybe? I had one once that was slowly failing and gave stupid readings like that.
  3. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    You got system restore switched on for the drive?
  4. Margo Baggins
    28 May 2010
    nah system restore isnt on for the drive. The drive is only about 2 or 3 months old, its not old at all.
  5. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    There's lots of data in the 'user' folder, someone else used it and downloaded a shed load?
  6. noizdaemon666
    15 Jun 2010
    Run SeaTools to check it isn't failing, even if it is brand new doesn't mean it can't fail. Other than that, possibly something wrong with the SATA port? Very unlikely but not a lot else I can think of.
  7. Margo Baggins
    28 May 2010
    Nah, im the only user of this pc, you're right there is alot there, but its about 130gb music, bt still if you add up all those numbers, is no where near close to what properties says it is.
  8. Margo Baggins
    28 May 2010
    so far has passed all the tests, just running the long test. Any idea why that drive is orange? Its the one with the "missing" space, all the others are grey.
  9. noizdaemon666
    15 Jun 2010
    Different make of hard drive, Maxtor and Seagate apparently use gold ones, whereas everything else is grey.
  10. gerardmcmanus
    gerardmcmanus What's a Dremel?
    11 Oct 2011
    possibly a virus duplicating data, I have had this on my last machine at one point, I ran down the directories until I found the files causing the problem, then deleted them, first time it crashed my system, second attempt worked but it took ages and I had to leave the pc while it did it, then after a few days there was no space again.
    Did a system wipe and reinstalled the operating system and this fixed the problem.
  11. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    Try running windirstat as administrator.
  12. faugusztin
    11 Aug 2008
    For example i managed this with FRAPS. I enabled desktop monitoring and then hit the recording key - so i ended up with my SSD full of desktop videos :D.
  13. Zurechial
    Zurechial Elitist
    21 Mar 2007
    Have you been playing around with symlinks?
    Windows doesn't behave well when it comes to calculating disk space on drives where symbolic links are in use, as it tends to subtract the storage space of both the actual file and the file pointed to by the symbolic link (ie; the same file) when calculating disk usage.
    This may have been fixed since I last checked, but I remember that being an issue sometime in the past where, for example, someone made a symbolic link to a 300Gb Steam folder and saw their free disk space plummet by 300Gb as reported by the OS, but without actually losing the space.
    Have you Chkdsk'd the drive?
    Also this.
  14. saspro
    saspro IT monkey
    23 Apr 2009
    Are shadow copies enabled on that drive?
    Could well be previous versions that's using that amount of space
  15. IDS-IPS
    IDS-IPS What's a Dremel?
    16 Oct 2011
    Google a app. By the name of "sequoia tree", it will create a visual map of everything on your selected drive, organised by size.
    Good luck.
    Sent from Bittech Android app
  16. TheManicGibbon
    TheManicGibbon I have no idea what's going on
    12 Aug 2009
    TreeSize also shows you what files and folders are the largest on your hard drive, hopefully showing you where this space is being lost.
  17. Margo Baggins
    28 May 2010
    I opted to move everything onto another hdd and format this one, problem solved. I cannot still work out what had happened. I tried using various space diag programs, that would show all the folder/file sizes, yet none of them would equal the size properties said was on the disk. Bizarre, well its all happy days again now. Thanks all for input :)
