Storage HDD to SSD clone question
Discussion in 'Tech Support' started by Meaty Pete, 26 Jan 2012.
  1. Meaty Pete
    Meaty Pete King of the Potato People
    8 Apr 2010
    Hi guys just a quick one -
    I have a netbook and want to replace the HDD with an SSD I have.
    I just want to clone the drive like for like but having used a few different types of hard disk software I can't seem to find one that will just clone the whole drive like for like (partition for partition).
    They all seem to want to image only one partition at a time which isn't working (quite possibly because I'm being dim) :duh:
    Anyone know how I can just clone one drive to another with it doing all partitions and info in one go?
    Thanks for any help
  2. CoffeeTwoSugars
    CoffeeTwoSugars What's a Dremel?
    9 Jan 2012
    Hi
    I have used Virtual Clone Drive in the past, I'm not sure if its does all the partitions however, but it worked very well for me
    What programs have you used so far?
  3. Meaty Pete
    8 Apr 2010
    Just googled that and it seems to be DVD cloning software, or am I being a massive fool? :duh:
  4. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Search for hirens boot cd 13.0. It has Acronis true image home 2011. Its really simple to use and works everytime.
  5. Teelzebub
    27 Nov 2009
    Acronis true image is the best.
  6. sandys
    sandys Multimodder
    26 Mar 2006
    I did this using ubuntu live cd and a command called dd after putting both old and new drives in my PC, I then resized the new drive with gparted.
    kept all rescue partitions etc.
    you can find plenty of guides on google
  7. moorsey
    moorsey What's a Dremel?
    10 Oct 2009
    +1 for Acronis, if you fancy open source goodness, then Clonezilla is superb software also
  8. Bungletron
    Bungletron Minimodder
    25 May 2010
    easeus is free, you must select clone DISK not partition, regardless you may have issues if the SSD you are cloning to is smaller than the original HDD.
  9. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    a paidfor version of HDClone can shrink partition sizes whilst cloning.
