Modding HDD Window
Discussion in 'Modding' started by alacritous, 10 Sep 2004.
  1. alacritous
    alacritous What's a Dremel?
    1 Jan 2004
    Hello,
    I want to make a window in a hard disk drive. I read the article, but I'm confused on a few things. I recently did a plexiglas project, and was wondering if a standard jigsaw could cut the metal. I'm not worrying about it being not strong enough, but if it'll damage the blade or something. The next question is how to glue the plexiglas into the metal. I read that the person in the article used some sort of a model glue. I was just wondering if there was any type of common glue that can be easily found in some store that would work.
    Thanks,
    Alacritous
  2. Rekarp
    Rekarp What's a Dremel?
    7 Mar 2004
    sure a jigsaw will cut it but you need a medium to smooth metal blade for it. To attach it just use some kind of adhesive like goop.
  3. Springs
    Springs Boing boing
    29 Aug 2004
    of what i have read of hard drive windows.. you have to use a thin bit of plastic and if its to thick the drive wont spin... of 1 of the guides i have read they had to use a piece of see through plastic from a folder as everything else was to thick...
  4. lord nicon21
    lord nicon21 sexy *******
    29 Sep 2003
    you could just take the metel ff and change ifor a bit of plastic so it can be as thick as you want it to be
  5. WILD9
    WILD9 Been here aaaaages
    13 Sep 2001
    You are doing this on an old disk arnt you? I dont think theres ever been a record of someone doing this with a high density mordern disk and it not breaking it after a time.
  6. juzzwuzz
    juzzwuzz What's a Dremel?
    4 Jan 2004
    I read somewhere of someone doing it to a 200Gig or something and it worked perfectly. Can't remember the link now. :wallbash:
  7. Nexxo
    23 Oct 2001
    Sounds like an urban legend to me: "A friend once told me that a friend of his...". :p Anyway, everyone gets lucky once. Sometimes HDDs keep working after the mod for a week or so, until that stray particle finally finds a good home between the head and (a vital data carrying bit of) the drive platter. It's just a very risky mod.
  8. juzzwuzz
    4 Jan 2004
    Thats the only problem with this kind of mod is that it might work for a while but then it just dies. :waah:
  9. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    If the top of the hdd has a screw going to the axle for the platters, than this mod won't work. If it only has screws on the edges, than it should if you don't contaminate it.
  10. Springs
    Springs Boing boing
    29 Aug 2004
    u can do it with any hard drive.... you only make the window where the main disks are and not where the middle screw is...
  11. Rekarp
    7 Mar 2004
    or you can drill a hole were the screw is?
  12. Springs
    Springs Boing boing
    29 Aug 2004
    i would only do a partial window where the main disks are and then put a LED on the board to light it up :D
  13. alacritous
    1 Jan 2004
    Hello,
    Sorry, kind of forgot about this post. Can you tell me where to cut? (e.x. save image and draw on paint)
    Any other ideas/suggestions greatly appreciated.
    Yes it's an old drive.
    Please clarify, and look at the picture I am showing.
    Bit too complex for me :). If you want to see my work, search the forums for my name and goto the Alacritous Network Server topic.
  14. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    I'm not really sure you should try this... Not being funny but if a few LEDs are "too complex" for you, I think you'll have trouble with this. I've seen people do it in a self-contained box especially built for the project (To stop dust) and the drive still fails. However if you want a drive to throw away after, then by all means do it :thumb:
  15. BvBart
    BvBart What's a Dremel?
    29 Jul 2004
    Well, if you were doing it to get a good job done, you could always get another, similar, dead drive that you weren't worried about and take the cover off that bit. Then, do the window on THAT cover, and any other applicable modding, and test it for airtightness. Then all you'd have to do is switch lids, still being super careful though.
  16. alacritous
    1 Jan 2004
    Well I'm no where near thinking about donig it like you suggested. After I take off the top (metal plate thingy), I'm putting the actual hard drive in an air tight bag and doing that away with until it's done. I'm basically following the guide on this website, I was just asking a few questins.
    Alacritous
  17. Redd_Herring_1974
    Redd_Herring_1974 What's a Dremel?
    3 Sep 2004
    i'm with the others ive never seen someone do this successfully and the bag thing might work but it didnt for mashie on the y2k bug project if i remeber correctly 2 drives died in the makeing of that mod twas a shame it didnt work though :waah:
  18. Protius-X
    Protius-X What's a Dremel?
    31 May 2004
    Don't do it! After you do it your hdd generally only lasts for about 3 years maximum!
  19. Rekarp
    7 Mar 2004
    well im going to throw away my 5 year old 3 gig off brand hd but i think it can make one shot at becoming windowed
  20. DanMcr
    DanMcr What's a Dremel?
    27 Jul 2004
    My 10gig fujitsu just died after a couple of months of it working perfectly. :waah:
    The drive had 2 screws in the top, one for the disk axle, the other for the head. Didnt have any problems after the mod. But who knows, that may be the reason why it died in the end.
    Bloody shame too, it looked awsome. Used 3mm clear acrylic for the actual window, then made an enclosure for the whole drive out of 3mm blue UV reactive acrylic.
    Looked great when lit up.
    Gutted. :sigh:
