A/V HDMI Switch Recommendations Please!
Discussion in 'Hardware' started by Blogins, 7 Jan 2018.
  1. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    As the title states I'm in need of a good quality HDMI Switch. My TV has 3 HDMI inputs currently occupied by a PS4 Pro, XBOX One X and PC. I'll keep the consoles connected directly but need a switch that'll handle my PC and maybe 4 other 1080p HDMI devices. Are there any 4K capable switches for a reasonable price out there? Recommend away! :thumb:
  2. Kronos
    Kronos Well-Known Member
    6 Nov 2009
    Blogins likes this.
  3. Vault-Tec
    30 Aug 2015
    The small ones are very hit and miss. I have one on my 65" TV, never skips a beat. However, on my 24" HDMI monitor that was used as a TV when my wife took the one from the bedroom it refused to play ball.
    So I got a manual switch with press buttons on it for around £30 IIRC. It was still much cheaper than buying a whole TV. Give the cheap one a go first though. Nothing to lose at that price :)
    https://www.ebay.co.uk/itm/5-Port-1...300445&hash=item2cc7969802:g:i7QAAOSwi~5Z11Xg
    Try that first.
    Blogins likes this.
  4. Blogins
    3 Aug 2010
    Thanks for the advice guys! :thumb:
    Had considered the Kinivo before but the 501BN is pricey for what it offers. Might go the cheap route as Vault-Tec suggested.
  5. faugusztin
    11 Aug 2008
  6. Blogins
    3 Aug 2010
  7. faugusztin
    11 Aug 2008
  8. Blogins
    3 Aug 2010
    The 3-port version seems to be of a higher specification so I went for that one.
    Installed it the other day and it's a very nice piece of kit. Works with the Sky Q Mini Box and surprisingly it does do 4K with my PC and the XBOX One X! So the promise of 4K at 30Hz was not an empty one, colour me impressed! Currently powered with the included Micro USB cable via the TV itself. Not tried the infra red eye and the remote and probably won't. The circular feature on the top (pictured below) is a switch in itself to select between HDMI sources so that'll do me. Don't think that was mentioned in the units literature so thought it worth stating here!
  9. Porkins' Wingman
    Porkins' Wingman Can't touch this
    23 Feb 2008
  10. Blogins
    3 Aug 2010
  11. boiled_elephant
    boiled_elephant Whitelist Bit-Tech in your adblock!
    14 Jul 2004
    I'll swear by U-Green as a rule of thumb, I've used their external VGA block things (that go USB+VGA to HDMI) and they work very well. They're cheap Chinese stuff, but they're not bad cheap Chinese stuff, if you see what I mean. They're an actual brand.
  12. faugusztin
    11 Aug 2008
    As long as you don't mind sometimes getting a HDMI cable with Enthernet (not my typo, Ugreen's :D).
  13. dosmel
    dosmel New Member
    31 Jan 2018
    I have a UGREEN also and it works great. It won't automatically switch to the latest input, but the good thing is that there's a remote control.
