A/V HDMI to display port
Discussion in 'Tech Support' started by CrapBag, 23 May 2025.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Is there anything I'm missing here.
    I have my old HP ZR24W monitor going spare so I came up with a plan to use it with a fire stick in the spare room.
    Now this monitor doesn't have hdmi so I buy an adaptor and hook it all up but nothing is displayed.
    **** adaptor or do I need something else
    My soon has two display port to hdmi cables for his monitors and they work fine so why not this?
    https://www.amazon.co.uk/gp/aw/d/B017Q8ZVWK?psc=1&ref=ppx_pop_mob_b_asin_title
  2. Gareth Halfacree
    4 Dec 2007
    That's an adapter for going from DisplayPort on the GPU to HDMI on the monitor. You need the exact opposite.
    Byron C likes this.
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
  4. Gareth Halfacree
    4 Dec 2007
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Would HDMI to DVI also work as thats cheaper?
    Oh i will need audio so thats going to be an issue so probably not then.
  6. gamesaregood
    gamesaregood Modder
    8 Apr 2004
    Would this not be the wrong connections for what you need though?
    How about this?
    https://amzn.eu/d/7s3fE1e
    Edit / just realised that hp monitor replaced the
    LP2475W I used to have, I think bought from here at some point, takes me back great monitor.
    What are you going to do about sound? I don't think it has built in speakers?
  7. wyx087
    wyx087 Multimodder
    15 Aug 2007
  8. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Wrong direction for this one I think, Monitor is DP and the firestick is HDMI, someone in the reviews said it didnt work when they tried it.
    I'm going to hook up a speaker as the monitor does have uadio out but as you say, no speakers.
    That looks like the right thing but as you say I will need an HDMI female to femal to use it, I have a DP lead for the other end.
    wyx087 likes this.
  9. gamesaregood
    gamesaregood Modder
    8 Apr 2004
    Sorry your totally right, was having a complete moment looking at the connectors thinking it was right :(
  10. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    The one suggested is now out of stock and another one I've looked at says it won't work with an HDMI switch I was going to use as female converter.
    I'm starting to think it would be easier to give my wife the HP monitor and take her Asus then I won't have to muck about with adaptors but I love my HP.
  11. mrplow
    mrplow obey the fist!!
    5 Sep 2001
