Tips HDR and maybe some help?
Discussion in 'Photography, Art & Design' started by NzC, 3 Nov 2008.
  1. NzC
    NzC What's a Dremel?
    7 Sep 2003
    OK, so as many of you may have guess I take lots of photos, but I rarely do any post-processing thats more than some exposure or contrast tweakage. Every once in a while though, I like to dable in some HDR, though I use it very rarely. Today I got an image that you will see below using HDR. I love what it does to the lover halp with the tires, but I HATE THE F-ing SKY!! What do you think, and what can I do to fix it? If anyone has any ideas, let me know not just what but maybe some tips, cuz I am not very advanced with PPing....
  2. Firehed
    15 Feb 2004
    Get an entirely separate photo of a good sky and just photoshop it in with some masks and color replacement.
    I like the bottom half though, as far as hyper-real HDRs go. Framing and subject are good :)
  3. Silver51
    Silver51 I cast flare!
    24 Jul 2006
  4. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    Thanks Silver51 for that link, very useful indeed!
  5. eeevan
    eeevan Dremel Master
    21 Oct 2007
    Yeah, also not a fan of the sky/accompanying halo effects.
    What software did you use to generate this? Consider maybe trying something new.
    Apart from the sky, it's not bad.
  6. Silver51
    24 Jul 2006
  7. NzC
    7 Sep 2003
    So I actually went back and captured an almost identical image with better sky and I think I like it. I mean its HDR so I go for the not quite realistic look, FYI!
  8. DeMoB
    DeMoB All of my Dremel wheels are broke!
    10 Jul 2008
    The Halos kind of spoil it for me, but I do like the strong colours.
    Are you using photomatrix? And if so did you note this bit of advice on the vanilla days tutorial?
    Those those dark spots on the sky look like dust in your camera, do they show up on a plain test shot?
    Dan
  9. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Try editing the sky and the ground separate, and then blending together in PS.
  10. Silver51
    24 Jul 2006
    If you're using Photomatix, you could try one of these settings and tweak from there (taken from the vanilla days guide.)
    Natrual Feel
    Luminosity +8, Strength 25%, Colour Saturation 65%, White Clip 0.220, Black Clip 0.075
    Natrual Feel 2
    Luminosity -2, Strength 80%, Colour Saturation 65%, White Clip 2.230, Black Clip 0.490
    Creative
    Luminosity +5, Strength 75%, Colour Saturation 65%, White Clip 4.305, Black Clip 1.140
