A/V Headphones / Headset
Discussion in 'Hardware' started by BennieboyUK, 24 Sep 2011.
  1. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    Hi all,
    I am looking for a set of headphones or headset for around the £70.00 mark.
    Primary use: Gaming
    Secondary use: Music
    Microphone is optional, if it comes with one great if not no big deal.
    I have read 100's of reviews and it seems that the 50-80 market is flooded with products. Does anyone have any exposure to any of the following that they can advise on:
    AKG K520's
    http://uk.akg.com/product-detail-2821/k520wht.html
    AKG K121 Studio's
    http://www.soundonsound.com/news?NewsID=11183
    Razer Carcharias
    http://store.razerzone.com/store/razerusa/en_US/pd/productID.169415800
    AKG GHS 1
    http://www.bit-tech.net/hardware/peripherals/2011/01/29/akg-ghs1-camouflage-review/1
    Creative Sound Blaster Tactic 3D Sigma
    http://www.bit-tech.net/hardware/peripherals/2011/01/22/creative-tactic-3d-sigma-review/1
    Or does anyone have any other ideas around the £70.00 mark, I would like to avoid USB ones.
    Thanks
    Bennie:D
  2. Jaybles
    Jaybles New Member
    12 Feb 2011
  3. BennieboyUK
    24 Nov 2010
    I have looked at these, a little over my price range... is the extra really worth it?
  4. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    yes
  5. TARIKK
    TARIKK Member
    19 Feb 2009
    BennieboyUK likes this.
  6. BennieboyUK
    24 Nov 2010
  7. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
  8. Jaybles
    Jaybles New Member
    12 Feb 2011
    The Corsairs are good, but positioning is amazing on the Audio Technica's because of the wide soundstage. The open back on them gives a lot of sound leakage, but you get the enhanced directional accuracy.
  9. BennieboyUK
    24 Nov 2010
  10. Otis1337
    28 Nov 2007
    theres a reason there cheap... :p
    And there s reason The Asus Vulcan got 92% premium Grade reword ;)
  11. BennieboyUK
    24 Nov 2010
    so it is a toss up between the Vulcans and AD700's... if I can find anywhere that have the Vulcans in stock!
  12. Blue Fiend
    Blue Fiend New Member
    1 Jun 2010
    Go and get the ad700s. They are the best headphones for gaming for price due to soundstage.
    Other headphones would be the sehn hd 598 and 595 and 558 and 555 (518 and 515 suck)
    The 558 and 598 are the newer models but have no diffidence in sound but only a removable cable. Another one is the dt770
  13. Sexton
    Sexton Member
    2 Jun 2010
    Roccat Kave.
    The Creative Sigma's you mentioned are brilliant too.
  14. Skeese
    Skeese New Member
    2 Sep 2011
    These +1 :thumb:
  15. BennieboyUK
    24 Nov 2010
    Torn between the two of these, but the sound leakage finally pushed me to choose the Vulcans. I play almost all my games at night, with small baby and wife that is "all done" by 9:30pm, I think the Vulcans will be better with the closed backs.
    To be honest anything will be a upgrade from the £10.00 tesco in ears I am using at the moment.
    Thanks for the info from all
    +Rep given to those that supplied views and info.
    Only downside is that scan dont have them in stock. Ordered from OCUK, lets hope to God I don't have to RMA...
  16. Otis1337
    28 Nov 2007
    sennheiser headphones, particularly the gaming one's are highly over rated, as iv used ones that cost £120 before and sound crap compared to my old SteelSeries that cost £50 and nothing compared to my Vulcan's.
  17. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
  18. WiryRocketeer
    WiryRocketeer Member
    30 Jul 2010
    I'm also maybe considering getting the Vulcan's...tempting! Also, they're back in stock at scan :p
  19. longweight
    7 May 2011
  20. thehippoz
    thehippoz New Member
    19 Dec 2008
