Peripherals Headset <£30
Discussion in 'Hardware' started by Plugs, 5 Jun 2011.
  1. Plugs
    Plugs Minimodder
    5 Nov 2009
    Hi
    I had a Plantronics GameCom 377 headset, until it snapped (within its 1yr warranty), so I am looking for a replacement.
    I'm not really a hardware guy. So maybe someone has some good headset suggestions.
    Considering the 377 can be bought for ~£21 inc. delivery, and i was happy with it until it broke, my maximum budget is £30.
    I'm happy to consider separate headphones and a clip on mic, if you can find the two within the budget.
    Likely will be buying on Tuesday - so if nothing is suggested, I guess i'll try the 377s again.
    Thanks for reading and your suggestions.
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I can't think of anything that's as good for the same money.
    I have a pair of 377's, rather concerning that yours snapped :(.
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    JVC HA-RX700 every time.
  4. Plugs
    Plugs Minimodder
    5 Nov 2009
    Hmm, that plus a separate mic will be nearer to £40 though.
  5. Plugs
    Plugs Minimodder
    5 Nov 2009
    Any other ideas?
    Or has the dust settled on "Try the 377 again"?
  6. docodine
    10 Feb 2007
    It would be worth stretching the extra £10 for the JVC, they probably won't break within a year either!
