I have a Thermaltake Tte Sports Shock One Gaming Headset. For some reason in Power DVD 11 whenever I try to play a DVD or Bluray Disc the program seems to disable my headset from working with the program. I can re-enable my headset while I am in the program but for some reason no sound comes out even when it is enabled. I have tried playing around with the audio settings in the program and it continues to do the same thing. The sound works if I plug in my speakers but they aren't very good hence why I use my headphones. If someone has a solution to this that would be ultra helpful! Thanks!
What sound card are you using? Some I've come across detect headphone jack and reduce the volume as not to blow out your ear drums.
