Modding Heat gun on primer and paint. Will it work ?
Discussion in 'Modding' started by fuksis, 18 Dec 2004.
  1. fuksis
    fuksis What's a Dremel?
    16 Dec 2004
    Well guys I did search and appears no one has asked this question.
    Well the question is; is it a good idea to use a heat gun or hear dryer (for cheep moders like myself) to dry paint faster, will it work on primer ?
    What is a recommended distance temperature?
    Have any of you don it as waiting 2 days for primer after that paint and a clear to cure is a bit long time.
  2. x-caliber
    x-caliber What's a Dremel?
    18 Dec 2004
    Well, I painted my case in sub 30 degree farenheit weather.
    The best thing is heat up the parts before you paint.
    I put the steel parts in front of the furnace and warmed them, then I took them outside and put a coat of paint on. Then brought back in.
    I also took a small propane heater, and put it under my parts and baked the paint on. (from the backside)
    Use thin coats of paint/primer.
    2 days is good time for a wet sand / rub out of clear.
    If you get too close with a blowdryer, you will melt the paint.
    If you dont wait till the primer is dry before painting and then blowdry it, then you will bleed the paint/primer into eachother.
    Remember that with a blowdryer, your surface drying the paint.
    Will it dry paint faster, will it work on primer ? yes, I do it.
    Temp is not as big a deal as distance. I usually put my hand out in front of the heat gun/blowdryer. If its too hot on my hand then its too hot for the paint.
  3. fuksis
    16 Dec 2004
    Sweet advice men appreciated
