(Heat)sinking feeling
Discussion in 'Hardware' started by alpha112, 19 May 2005.
  1. alpha112
    alpha112 Minimodder
    23 Aug 2004
    Im looking for a new heatsink for my 3.4 HT Northwood because it seems to be at ~50 degrees idle, which Im lead to believe is not good. This could be my motherboard (IC7 MAX3) overestimating the temps, but I want a better one than my bog standard Akasa anyway.
    Im thinking of getting a Silverstone NT01 from Komplett for £26 with a couple of silent fans. But first I was wondering if anyone else has any experiences with this heatsink/motherboard combo, or just the heatsink in general. I was thinking maybe the OTES would get in the way of it.
    Also any suggestions on good heatsinks whould be appreciated, thanks.
  2. riluve
    riluve What's a Dremel?
    29 Jun 2004
    Is that really that bad? I am happy with anything under 60. Heck 53 makes me estatic.
    Most procs are specked out at 70-75, so uh, anything under 70 is more than fine.
  3. alpha112
    alpha112 Minimodder
    23 Aug 2004
    I was hoping to start OCing it when my new RAM arrives (new BH5 I think Ill get) and this is only going to push the temps higher so a better cooling solution seems logical.
  4. BrokeEnthusiast
    BrokeEnthusiast What's a Dremel?
    28 Mar 2005
    Watercool that thing
  5. riluve
    29 Jun 2004
    Well, ok, then I understand the worry, but cooling capacity at idle is not a good indicator of cooling capacity under a full load. I am no expert on cooling/over clocking, but what you should try is Folding at home or SETI - these will put 100% load on you processor. See how your heatsink handles that.
    personally, I use Hyper 6 and it kicks arse - but for an air-cooled heat sink, it can depend more on your environment than anything else.
    I mean where are you? If the room the computer is in is 100 degrees, don't expect your heat sink to be a lot of help. If you don;t have good case ventelation, etc - then no air colled heat sink is much better than the next.
  6. alpha112
    alpha112 Minimodder
    23 Aug 2004
    Well the room its in is currently 18 degrees. The case has 2 fans next to the processor (blowing across it), 2 on the power supply just above it (moving air out) and the OTES fan.
    Im running Burn In now to test temps, its at 59 degrees already after 2mins.
    EDIT: Its hitting an easy 65 nad I dont want to push it much more. As for watercooling, Id like to, would be a lot quieter than the fans I have at the moment but I dont think I can afford it.
  7. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    your using a precott core its gonna roast unless u have some ducting to cool air (maybe some ducting to the front of the case, cut a hole and mesh it?)
    or put it under water.
  8. alpha112
    alpha112 Minimodder
    23 Aug 2004
    I have a northwood, if it was a prescott I wouldnt be so worried about the high temps, they seem to come with the territory.
  9. Is it a question..
    Is it a question.. What's a Dremel?
    27 Feb 2005
    :brrr: alright chief. ive had a similar problem with my rig when it came to temps. scarily enough last weekend my cpu fan failed and my core hit a whacking 95 degrees C!!!! if you dont want to look at watercooling then for a good heatsink look at pure cooper with a large surface area covered by the fins. my mate swares by the asus star ice series heres the link
    if sound isnt too much of an issue, like me, i added a thermaltake 80mm performance fan@2800-3000rpm to the thermaltake ducting mod (eliminates fans centre dead spot) and ive lost a whole 10 degrees in temperature :rock: . it didnt cost much and works amazingly on the original cooper coolermaster heatsink ive got.... best of all it looks wicked aswell. you can use ANY 80mm case fan for the ducting mod so you can really go for 4800rpm or more, coloured or not, up to you.
    dont forget though if the inside air of ur pc is warm then ur cpu fan is just blowing warmish air onto the cpu which aint a fat lot of use :waah: . also make sure the cpu fan is not pointing towards ur psu as this can be a huge heatsource. if youre worried bout ur temps then look at ur whole setup not just cpu heatsink and fan. for instance ive got 5 case fans + cpu fan + gpu fan and my temps run at 32-34 idle and 36-40 on full load and mobo never goes above 16. good luck lowering ur temps......
  10. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    You could try a zalman 7000Cu cooler with a duct to the case side. That'd truely kick a** temps wise.
  11. Guest-16
    Guest-16 Guest
    They didnt make 3.4GHz northwoods.
  12. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    My thoughts exactly...
    Run CPU-Z and be sure of your core. 65C for a Prescott isn't horrible, it's just not ideal. All depends on what you want, though. What's the most important: best overall cooling, quiet, lower profile, cheap...
  13. alpha112
    alpha112 Minimodder
    23 Aug 2004
    Its definitely a 3.4GHz HT Northwood, unless Im missing something. I looked at a Zalman but it doesnt fit on my board afaik. That hyper 6 looks good though.
    Thanks for all the replies so far.
  14. Mother-Goose
    22 Jul 2004
    try one of the Artic Cool Freezer's
  15. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    'Fraid they did, they came out at the same time as the first Prescotts and the 3.4GHz EE :)
  16. TMM
    TMM Modder
    12 Jan 2004
  17. riluve
    29 Jun 2004
    looks good, but I know it wouldn't fit on any of my boards. it does overcome the hyper 6 main weakness - it works better as a horizontal (destop) than vertical (tower). But the weight really isnt a problem - well I use decent mobos, so maybe on cheap ones it may snap them in half, but thats what you get for going cheap. Though cheap does seem popular - so to avoid a flame war I won't mention any names.
  18. Guest-16
    Guest-16 Guest
    :eeek:
    every days a school day.
    musta been a damn quiet release.
  19. Kameleon
    29 Apr 2003
    Of course it was, everyone was too busy with their Prescott Oven Gloves™ :D
  20. TMM
    TMM Modder
    12 Jan 2004
    roffle :hehe:
