Cooling Heatsink for Core 2 CPU
Discussion in 'Hardware' started by sbarts, 2 Oct 2007.
  1. sbarts
    sbarts What's a Dremel?
    1 Nov 2004
    I'm looking for a decent and easy to install (Don't really want to remove my motherboard from the case) heatsink. I'm currently using the supplied Intel one which isn't to bad on the niose and installation front but is not the best cooler in the world. Any suggestions greatly appreciated.
  2. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    what mobo & are you overclocking?
    budget?
  3. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I have just installed an Arctic Cooling Freezer 7 pro. It has simple push pins, so all you need to do is remove the old heatsink by rotating the pins, clean the processor and stick this one on. It comes with its own pre-applied thermal paste which seems to work ok.
    It has dropped my temps by about 12C (CPU) and 4C(MoBo) but I have found it a little noisier, although I haven't yet adjusted the PWM control for it.
    EDIT: and it only cost about £17
  4. sbarts
    1 Nov 2004
    I've got the Asus P5B and have moderately overclocked my E6320 to 2.5.
  5. quack
    quack Minimodder
    6 Mar 2002
    I also have an Arctic Cooling Freezer 7 Pro, awesome cooling power!
  6. Guest-16
    Guest-16 Guest
    Freezer 7 Pro - cheap, easy to install, works well.
  7. tzang
    tzang Traditional Nutter
    7 Jun 2007
    Another vote goes to the Arctic Cooling Freezer 7 Pro. Well priced, good cooling and quiet.
  8. sbarts
    1 Nov 2004
    Looks like I know what i'm getting now. I'm off to find the cheapest place. Thanks all.
  9. thefriscokid
    thefriscokid why s**t so crazy?
    30 Aug 2005
    zalman 9500 led
  10. dr_bowtie
    dr_bowtie What's a Dremel?
    3 Oct 2007
    I'd get a Zalman 9700 if I were going to get one...not much more and tons better...I love mine and installation is a breeze...
  11. iwog
    iwog Linux cursed
    14 Jun 2007
    My vote goes to the Arctic freezer pro too, I have the 64 version, for an amd only difference is the mounting bracket, and have never had a problem with it.
  12. DarkReaper
    DarkReaper Alignment: Sarcastic Good
    9 Jan 2004
    Scythe Ninja can go in fanless if you want, or attach a fan to it for really nice cooling. It is more pricey though
  13. morris8809
    morris8809 Minimodder
    30 Dec 2006
    well to me the intel heatsink works great, my e6300 idles at 28C and maxes at 38C.
  14. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    I have a thermaltake maxorb. easy to install, no force required when putting the pushpins in. not that expensive either.
  15. Elio
    Elio What's a Dremel?
    4 Oct 2007
    friend of mine bought the maxorb by thermaltake got great results.easy to install cheap and reasonbly noisy when fan on max rpm...
  16. ccsharry
    ccsharry What's a Dremel?
    21 Sep 2007
    thermalright ultima 90i!! never go for zalman!! they are noise and inefficient!!
  17. DarkReaper
    9 Jan 2004
    Have you actually used many Zalmans? And how can a heatsink be inefficient, anyway?
  18. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    I rather like the Zalmans I've used, especially for graphic card cooling.
  19. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    you could also try the asetek vapochill micro... its on par with some watercooling kits (koolance exos-2 and aquagate mini), cools surrounding areas of the mobo, and weighs only 355g with the fan
  20. wyx087
    15 Aug 2007
    the Zalman 9500 is currently the most noisy component in my PC while gaming........ i would recommend Freezer Pro 7 or a Tuniq Tower 120
