heatsink weight ????
Discussion in 'Hardware' started by Qbank, 26 Jun 2002.
  1. Qbank
    Qbank What's a Dremel?
    19 Jun 2002
    I have a athlon amd xp 2100+ and now there's a Taisol GK760092 on it it weighs about 264 g i'm planing to take the 60mm fan off and put a Ice hole on it +- 160-180g and on top of that an enermax fan +- 85 g i think that the 60 mm fan has a weight about 26 g
    so
    264
    - 26
    + 170
    + 85
    ______
  2. Qbank
    19 Jun 2002
    = 493 g
    493 g is that to much ??? or is that stil ok ????
  3. relix
    relix Minimodder
    14 Nov 2001
    well I think that's still okay because a waterblock won't wheigh much less I think, but I'd wait for confirmation of the real techies over here
  4. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    That weight should just about be ok for three lugs.............but only just and take care! If any lugs are broken or you are not using all three then you should be far more wary
  5. Guest-16
    Guest-16 Guest
    on 3 lugs it should be ok.
    Official weight for AMD is 400g though.
  6. RTT
    RTT #parp
    12 Mar 2001
    Thats heavy but you should just about be ok :)
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's not just the weight, it's the leverage from the extra height.
    But with the 3-prong Taisol you've got the next-best fitting to using the mobo holes.
    Just don't move the case about a lot (ie. lay flat when transporting). :eeek:
  8. RTT
    RTT #parp
    12 Mar 2001
    Its actually called a 'moment'
    you can work it with something like Length x Force (N)
    I did all that about 2 years ago, so thats probably wrong :blush:
  9. Qbank
    19 Jun 2002
    would it help if i seported ?
    Wat if i seported it white to smal cables like put them arond the 2 top srews of the fans and suspend them to the top of the case ?
    would it help or is it not neseserie ?
  10. RTT
    RTT #parp
    12 Mar 2001
    You could yes, but make sure it isnt too tight as to offset the HSF on the actual CPU die :)
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    That's what me & the mrs have :D
    It's the distance between fulcrum or "hinge" (the clip) & the centre-of-mass of the hs/adapter/fan times the weight, IIRC.
    But I could be wrong, I've started having senior moments :cries:
