Equipment Heavy duty desktop tripod
Discussion in 'Photography, Art & Design' started by silk186, 5 Sep 2020.
  1. silk186
    silk186 Derp
    1 Dec 2014
    A friend gave me a Neewer 14-inch Outer Dimmable Bi-color SMD ... LED ring light. This one to be exact. My kitchen scale says the light is almost 1kg and is 1.2kg with the phone. I have a larger one, I forget if it is the 18" or 20" stuck in China. The delivery weight is only 0.8kg different according to Amazon so let's say 2kg for the larger ring with the phone. The included tripod is rated for 8KG. As such I think a 3-5KG rated desktop tripod would be nice and solid. I can use the included but that would place the light 110cm away from the subject.
    Any suggestions?
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Is it for the ground or a desk/table? As a clamp may ne a better option for the latter :)
  3. silk186
    silk186 Derp
    1 Dec 2014
    It will go on the table, with the phone mounted in the LED ring so I don't want it too far away. Normally the tripod is in the middle of the table or closer, around 50cm away.
