Modding heavy duty fan for blowhole
Discussion in 'Modding' started by malcs, 10 Aug 2003.
  1. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    OK i am going to do myself a 120mm blowhole i think and i need an appropriately sized fan to go with it.... i need really amazing airflow around 7000-8000 RPM cost doesn't really matter i just want to cool down my mobo!!! i would prefer a metal panaflo one if anyone knows where i can get one?
  2. Morphine
    Morphine weeee!
    23 Feb 2002
    hehehehehehe
    get yourself one of the metal papst AC fans. Ive got one, got it off ebay. Just wire it into your PSU or attaach a pulg to it. They spin so fast that when you try to shake it when its on it has a gyroscope effect and fights you. But they are LOUD! oh yeah, its blades are cpapble of chopping up unlofded paperclips if you stick them in.
  3. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    I really want to try out that 190CFM, 59dB 120mm Delta, but I really don't feel like paying £20 for the privilege :D
  4. malcs
    24 May 2003
    SERIES 6400 i want that papst fan :D aaaaaahhhhh would certaintly cool down my case lol!!
  5. malcs
    24 May 2003
    @morphine how do you get power to it?
  6. Morphine
    Morphine weeee!
    23 Feb 2002
    I just put a normal wall plug onto it and run it on my desk to cool me off. I even put a ight switch onto it to turn it on and off :) I'm guessing if you used a pump switch relay like the ones for watercooling you could ahve it turn on and off with your comp. I dunno if your serious or not about these fans, but they are LOUD. Maybe if you modded a dimmer switch for room lights into the fans power lines along with the relay you could have a sort of baybus for it and turn it lower.
    I'll see if i have any of those switches in my house somewhere and see if they quieten these down
  7. Blackeagle
    Blackeagle What's a Dremel?
    1 Nov 2002
    One of the keys to having high air flow is pressure rate of the fan to match the unrestricted air flow.
    I'd suggest a DV4112 diagonal flow type of fan that Papst has just announced. They will drive a full 25mm H2O pressure along with 150CFM of air.
    There is of course a down side to this sort of powerfull fan. A. They draw a lot more power than standard axial fans, in this case a 12v model draws 23 watts, yeah not a typo. B. They also produce around 55dba of noise, which is more than many care for.:waah: :wallbash:
  8. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    I have 2 salvage fans from old Oxygen Concentrators (They use them in Hospitals) that are metal, 120mm and 120V... I power them from wires soldered to the input on my PSU thru a relay from the 12V baybus in my pc... The 12V kicks on the 120V relay, and voila, instant major air.
