Motors heheh i will not be happy until i break part of my car
Discussion in 'General' started by samuelellis, 29 Nov 2005.
  1. samuelellis
    samuelellis New Member
    19 Apr 2002
  2. Tim S
    Tim S OG
    8 Nov 2001
    you have ears left?
  3. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    Or maybe your cerebral cortex has separated and now you must anoy everyone on the road.
  4. phantomxc
    phantomxc New Member
    7 Dec 2004
    i hope you dont part that outside, because where i use to live that would of been gone in less then a week. but i like my stock bose sound system ^_^.
  5. Shadowed_fury
    Shadowed_fury Active Member
    21 Nov 2003
  6. slater
    slater Mummy Says Im Special
    18 Apr 2003
    My car does that when i rev the engine. :/
  7. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    My car does that when I fart.
  8. samuelellis
    19 Apr 2002
    hmmm nice and that was taken at a db drag event someware you can turn it up
    bigz - yep still got my hearing :D
  9. atanum141
    22 Jul 2004
    whats tunes were you playing during the vid?
    the first one was a prodigy track i know..but what was the second one..
    maybe you should try some hip-hop...one suggestion for s dirty baseline track is deadprez-hip hop.
  10. samuelellis
    19 Apr 2002
    dead prez - hip hop is midbass tbh
    the last track was late night tip by 36 mafia
    try finding a song called woofer cooker by boston acoustics or bass i love you by basstronics
    or anything by bassmekanik
  11. micb
    micb Active Member
    4 Sep 2002
    New Toy!
    Lots if power into 1 ohm!
  12. samuelellis
    19 Apr 2002
    meh i will stick with the audio-system for now
    well if i can afford project X the audio-system will end up running my fronts (2 X 230 4ohm stereo)
    and i bet the new toy i got delivery of is shinier :p (not to do with car hifi though but it will be coming with me at shows)
  13. Malvolio
    Malvolio .
    14 Dec 2003
    Not bad. My buddies system is running two 10" MTX subs and an MXA8001 mono-blocked down to 1ohm with a high end Clarion deck. And I must say, in his current box (half the trunk in a mx6 with one main vertical port between the two subs) his system can be heard about 2 blocks away at max without problem. You can feel it a block away. What your cell phone was doing is what my power drill does on his trunk :D
    We've actually opened up the trunk before and found a half dozen screws and bolts just laying on the mat - its just this side of nuts, I'll say that much.
    Mucho props to your system though :thumb:
  14. samuelellis
    19 Apr 2002
    when you consider that sub in my boot is in a well poor is not the word enclosure - you can sometimes see the enclosure flexing and it is only a £150 quid driver getting a good 4 times its rated power
    so its holding up
    project x will be insane if i get the cash for it
    prejext y will be insane-ish i cant afford prject x
    and project z will be funny as hell if i cant afford prejext x or y
  15. Krikkit
    21 Jan 2003
    Forgive me for asking, but what the hell is the point? Other than winning compo's, when exactly are you going to use it?
  16. Malvolio
    Malvolio .
    14 Dec 2003
    Bass has a rather soothing, calming type effect, so if one wants to chill out to music, and have their entire car rattle away, then this is the way you have to go. Realistically though, it's personal preference. Why would you want a better video card? It's only going to give you slightly better graphics, just like a better sub/sound system will only give you slightly better sound ;)
    All in perspective.
  17. samuelellis
    19 Apr 2002
    i thiknk you will fidn that is the car i drive daily hence the shot of the front components playing at the begining
    the point is that as i have a damn good hifi in the house the standard kit in the car was NOT cutting it so required aftermarket equiptment
    when the car doors are closed and the volume is dialed downt o my usual listenng level the car has very few rattles and has good sound quality for what it is
  18. CaPs_On
    CaPs_On New Member
    3 May 2005
    Thats nice! What kinda audio equipment do you use! And have you tested how high (db) you can reach?
  19. micb
    micb Active Member
    4 Sep 2002
    That MTX MXA8001 is around 536 less watts than my Crossfire according to CEA 2006 ratings :D
    Currently I'm running the amplifier at 1/4 power as my current sub is 4 ohms.
    Pioneer DEH 4700MP CD player
    RE Audio 6.5 midbass comps.
    Morel CR-103 Tweeters
    Crystal CAM 300.2 (150-175WRMS per front side).
    Crossfire VR1000D
    Infinity Perfect 10.1 custom Ported 1.1 cf net enclosure tuned to 26hz.
    Tommorrow I'm speding the afternoon trying out sub subwoofers to get more out of the amplifier!
    My midbass units tear my doors apart I'm going away this weekend to a very good friend installer to install £130 Dynamatt Extreme, add birch plywood to my front doors to turn them into fully sealed deadend speaker enclosures.
