Hellgate:Lian-Li
Discussion in 'Project Logs' started by Fozzy, 6 Jul 2006.
  1. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Looking forward to it then...
    Mod on!
  2. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    I know you started a few months back Fozzy, but I have not had the time to "surf" the PL's..until tonight..
    Yours stands out from the crowd..Let me say Excellent (clean) work and welcome to the LL Vseries family...Your window..very cool..
    And the dual-reservoirs in that location...A first..(and I love it)..
    Keep-it up...
  3. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Thanks, I'm looking forward to haveing the money to put down on the pumps : )
    Thanks. It's hard to be origional in the VSeries family since so much has been done already. I really am trying to stand out from the crowd if I can. Maybe you could teach me how to airbrush as well. I'm good at etching but this case begs for an airbrushed picture.
  4. Fozzy
    25 Jan 2005
    Alright so I've been to lazy to post any updates so this is more like 3 updates in one...so get ready.
    I finally figured out why I didnt get my fan with my case....Newegg gae them the wrong address. So after a quick trip to two different post offices...
    The box
    8 120mm Red LED Fans
    Haveing some fun
    More fun
    A stack of fans
    Powered up
    More fun. Surprisingly they are much quieter thanthe 80mm fan in my test PSU!
    Rear fan installed to test lighting
    Front fan installed
    This is the rear fan with the CPU Bracket...and yes I am leaving it on. More planned for that later : )
    Through the grill.
    Front view.
    This is my first update. If you post before I do there is still another update to follow in about 5 minutes.
  5. Fozzy
    25 Jan 2005
    Update two:
    I finished the left side window for the reserviors and I think it looks sick with lights behind it!
    Drawn up.
    Scrap Plexi for the rim.
    All cut out!
    Test fit.
    Mesh hammered through.
    Ready for mounting.
    Mounted!
    Now for the beauty shots.
    Lighted with the blue LED's (May be switched to red but I'm not sure yet.
    One more update to go.
  6. Fozzy
    25 Jan 2005
    Finally decided to use an old fan controller (/need it with all of the fans). I dont have the knobs yet but I got it fitted. I may add LED's Later.
    The controller.
    The Bay.
    Drill Template
    Mounted
    Installed
    The other thing I've been working on is the radiator/fan mount
    Here' is is all cut and ready to be installed on the case but I'll finish that tomorrow.
    Can anyone guess what I'd be planning with the scrap aluminum/angled aluminum? I bet you cant.
    What keeps me going untill 5 in the morning every night.
  7. OldY
    OldY What's a Dremel?
    10 Mar 2006
    WOW - Love all the lighting you have!!!! Those reserviors are fantastic - is the angled aluminium for the CPU fan bracket? Maybe around the radiator?
    Anyways, keep 'em coming
  8. Fozzy
    25 Jan 2005
    Nope and nope!
  9. trati629
    trati629 Can I Fix It? :$ Well Yes??
    13 Jun 2005
    I bet that you wont be doing any thing with it. You just wanted to send us on a wild goose chase.
    P.S. I really like the windows they look sweet and the window for the res's :rock:
    Keep the good work up im really impressed :thumb:
  10. Fozzy
    25 Jan 2005
    Hint. Modsquad did it in Project Soylent Green.
  11. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I read that whole worklog one day. so lets see. Either extending the PSU or lowering something under the chassis maybe your Eheim pump?
    I forgot to ask the specs. DB CFM and price of those fans they are sweet where di dyou get them?
  12. Fozzy
    25 Jan 2005
    Nope Nope and Nope. I dont even have an ehiem I have 2 mcp350's
    Fan Specs:
    Airflow: 77.26 CFM
    Noise: 35.48 dB-a
    Speed: 2000rpm
    It's a pretty quite fan.
  13. hydro_electric_655
    13 Jul 2006
    Hmm well then your dual pump brackets? I can't even think make an update stat. I was also looking into BFG NVidia Cards and their 7800 GTX OC was incredible at over $1000 so. I think I will be looking at some of the cheaper models. O well thats my sidetrack this should look really good. Fans are a little on the loud side but for 77.26 CFM you cant complain. Ughh I can't make up my mind to make a case.
  14. Fozzy
    25 Jan 2005
    They're like 3 bucks a piece on newegg and they come in all colors. Ohh and the 7900gt is better than the 7800gtx and only runs about $200 on ebay. It's probably what I'm getting.
  15. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Either a shroud for your rad or some knd of drive bay stealth ?
  16. Fozzy
    25 Jan 2005
    BINGO!! Drive bay stealth it is. I mocked it up and made a few cuts....it's not looking too good but hopefully with some patience it'll turnout alright
  17. Fozzy
    25 Jan 2005
    After work I decided to finish the radiator mount since I had finished the ring/mount the night before and I really wanted to test out some lighting. Sorry no progress pics this time because I was tired and in a hurry.
    Installed!
    More angles
    Lights out!
    You can kinda see how the light difracts through the ring. The effect is amazeing in person. You'll just have to trust me.
    The blue is definately staying as I think it mixe well with the red and i screams HGL. I love how the red is glowing everywhere. It's exactly the effect I wanted and I'm just tickled that it worked.
    Front
    Through the window
    Res's with the lights off.
    How it looks with the lights on.
    Well thats it for now. I'm working on the bay stealthing but it's crap right now so it may get ditched. Tell me what you think about the lighting (another three fans to be added in the bottom.)
  18. OldY
    10 Mar 2006
    Utterly Amazing!!!! That final shot is so mmmmmmmmmm!! It's one bright bugger in the dark. The red and blue go with each other!!!
  19. Muon
    Muon What's a Dremel?
    1 Dec 2004
    Pretty impressive as this is coming together! are those fans uv reactive? if they are, any plans to incorporate that?
  20. Fozzy
    25 Jan 2005
    Its pretty much perfect to me. The lights arent to blareing yet they attract all the attention in the room. It'll be nice at a lan party to have a red glow around me while i frag it up on CS:S (Or HGL which is prolly not going to be a frag fest.)
    Nope but it will be much to bright in the case for it t work anyways. For uv you need to have a very dark case with very bright accents.
