Graphics Hello eh
Discussion in 'Hardware' started by nofx, 6 Nov 2005.
  1. nofx
    nofx What's a Dremel?
    1 Nov 2005
    Hello,
    I just bought a 9600xt with stock cooling as well as a zalman vf700 cooler.
    I was wondering if anyone has a link to installing the a cooler on 9600 or if a forum with pictures of removing the stock fan from the card.
    If anyone also has setting of chip and ram settings for this card it would be helpful as well.
    Jon
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Zalmans website should have an installation guide, they usually have one for each product.
  3. nofx
    1 Nov 2005
    sorry
    its not installing the cooler that is the concern its the removing of the stock cooler i dont want to rip off the core iw ant to read a guide or something before i do it
  4. Shadowed_fury
    21 Nov 2003
    Ooh! Have it running for 10mins or so, just for it to warm up. Remove pushpins, and gently (very gently) twist and pull the cooler off. I've never killed a core this way.
    (Don't kill me, if you do)
  5. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    Make sure you turn the computer off and take the card out before you remove the pushpins. :thumb:
  6. Shadowed_fury
    21 Nov 2003
    Yeah, good idea. Though I did think that was slightly obvious... :p
  7. DivineSin
    23 Apr 2004
    Yea, its obvious to some people, but you NEVER know. Its good to tell people everything. :D
    I'm not saying the original poster is one of these people, but ya never know. You dont want him running back yelling at you because he fried his card and his mobo :worried:
  8. nofx
    1 Nov 2005
    well
    thank you shadowed_fury for tip on how to remove the stock cooler.
    went on fairly easy except the fan blades interfering with the screw holes.
  9. Shadowed_fury
    21 Nov 2003
    Good to hear it went ok :)
