Cooling Help attaching a Water cooling kit a laptop
Discussion in 'Hardware' started by despat, 23 Mar 2006.
  1. despat
    despat What's a Dremel?
    23 Mar 2006
    Hi,
    I'm trying to run a Water Pump from a laptop. The pump required 12 Volt and 8-10 Watts to run. Where can I get this power? I want to attach it via USB to that the pump starts with the laptop. Any ideas?
    Would drawing power from two USB ports solve the problem. I have a funny looking USB A to B connecter except that it has 2 USB A heads on one side. Will that be sufficient to run the Pump?
    Btw. I know water cooling a laptop not the ideal thing to do but its just a fun project.
    Thanks
  2. Sherk
    Sherk What's a Dremel?
    10 Jan 2006
    You won't be able to pull that much wattage off a USB port, it only supports 500mA. That's on 5V, too. (2.5watts per port). I'm not sure but you might be able to get that wattage internally, but you may have power issues then. Not really sure... the best bet (since the pump is external anyways) if you want it to turn on with the laptop, is a relay attached to the USB port and an external power brick.
  3. Nexxo
    23 Oct 2001
    The pump will require its own power supply. You could use the 5V line of the USB port to activate a relay that will turn on the pump. There is no way however to feed a pump from USB ports (not even two).
    In any case that would be the least of your problems. You'll be hard-pressed to integrate watercooling into a laptop. You'd have to engineer your own components to very high precision and unless you are a CNC-god that will be extremely difficult.
  4. Freedom
    Freedom Minimodder
    27 Oct 2004
    Well i can tell you with some simply maths that you require in best case 1.2amps. P=VI so I=P/V I=10w/12V I=1.2a
  5. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    I don't think it would be as hard as imagined. An add-on base could be constructed somewhat simply, and then this HDD block can be fixed at the top so that the laptop can be set ontop of it. While I don't think it will provide fantastic cooling, this method could be more effecient than using one of those ready made cooling pads.
    I recently considered such a configuration myself because my 5 yr old laptop has overheating problems but is otherwise a usable machine.
    By no means would this be a portable solution, but it could make for a useful/efficient docking station.
