Scratch Build – In Progress help building an ir led array
Discussion in 'Project Logs' started by donnybronson, 23 Apr 2009.
  1. donnybronson
    donnybronson What's a Dremel?
    23 Apr 2009
    hi
    im looking for some help building an ir led array
    i have about 140 10mm IR leds to power and i need to be able to do it from batteries...
    hi
    the leds claim to have the following spec:
    RADIANT INTENSITY 6mW/Sr If=20m/a
    RADIANT INTENSITY 30 mW/Sr If=100m/a
    FORWARD VOLTAGE 1.4—1.45v
    REVERSE CURRENT 10u/a
    i tried running 48 from 2x pp3 batteries in series but the current draw killed the batteries pretty quick and their internal resistance caused them to get pretty hot...
    pretty much the same results running a string of just 6 with two pp3's in series powering them. though they did last a little longer
    at the mo i have sets of six leds in series
    i need a pretty portable solution that offers as the best possible brightness fron the arrays and needs lolast for about 1-2 hours
    so which batteries to use? how many leds to connect ? series/parralel? additional resistors?
    thanks in advence guys
  2. Sushi Warrior
    Sushi Warrior What's a Dremel?
    20 Mar 2009
    Move this to the modding forum.
  3. donnybronson
    23 Apr 2009
    thanks for that will do
  4. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Ill send you a visitor messages on your profile.
