Other Help changing my lock
Discussion in 'General' started by silk186, 13 Mar 2019.
  1. silk186
    silk186 Derp
    1 Dec 2014
    I'm renting a flat and want to change the lock cylinder because it doesn't have a thumb turn and I caught someone trying to break in before. After some research, I ordered a Yale platinum thumb turn cylinder.
    The new cylinder arrived today and I realised my cylinder is an oval cylinder, not a euro cylinder :wallbash:
    Should I look for an oval cylinder with a thumb turn, I've not come across any that look decent.
    Or, I can convert the oval to a euro cylinder. I don't know if I should give up and buy a cheap oval cylinder or try to convert to the euro cylinder I have.
    [​IMG] [​IMG] [​IMG]
  2. wolfticket
    19 Apr 2008
    I'd buy a cheap (but reasonable) oval cylinder.
    silk186 likes this.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Converting the door to Euro would be costly and a PITA, can't you just leave a key in it?
    Failing that what wolfticket said.
    silk186 likes this.
  4. silk186
    silk186 Derp
    1 Dec 2014
    Leaving the key in it only works if you remember to remove it every time you go out. I has already cost me £70. I thought it would be a simple cylinder swap but I seem to have bad luck. I will order a cheap oval cylinder with a thumb turn before I lock myself out again.
  5. silk186
    silk186 Derp
    1 Dec 2014
    I'm looking and they are not very common. At least they are cheap.
  6. Mr_Mistoffelees
    Mr_Mistoffelees The Lunatic on the Grass.
    26 Aug 2014
  7. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Looks like a standard DIN lock body. Keep your Euro cylinder, pop out the curent lock body and slot in a new DIN body that accepts a Euro cylinder, then install it. OVal cylinders are getting less and less common, so that would set you up in the long run.
