HTPC Help Choosing Dual TV tuner
Discussion in 'Hardware' started by webbyman, 5 Mar 2006.
  1. webbyman
    webbyman Hax.
    7 Oct 2004
  2. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
  3. herbs
    herbs Nobody but us chickens
    7 May 2001
    One big problem the link you gave are for analogue cards not digital cards. There are two dual digital (dvb-t) cards that I know off, and one of them is a pci-e (TERRATEC 2400i) card the other is the fusion hdtv dual tuner card see http://www.kustompcs.co.uk/acatalog/info_4338.html but it's not cheap.
    If you have the space two pci cards will be cheaper or 1 pci and 1 usb2 tuner. If you want more info visit www.tv-cards.com
    Also the difference between the two you linked is that you get nvidia's dvd codec with the dearer one.
  4. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    can anybody recomend a card that is digtial and analog?
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  6. webbyman
    webbyman Hax.
    7 Oct 2004
    thanks for the replys,
    considering just getting a single digi tv card now, since >100 is a little bit too much thinking about it, looking at spending about £40-60 now on a single digital one which can record however im intrested in the hauppage 1100. :hehe:
