I have been looking around for a while now, and i cant decide on what RAM to choose. i know i want 4Gb (2 x 2Gb). But i cant decide between 1333Mhz and 1600Mhz. And then which CAS to choose. i was hoping to spend under £100. And i will be using my computer primarily for gaming. Heres my specs if it helps - CPU: AMD Phenom II X4 955 Black Edition Motherbaord: Asrock 890GM Pro3 Socket AM3 DVI VGA HDMI Out 8 Channel Audio I have been looking at these... G.Skill Trident 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit - F3-12800CL8D-4GBTD Patriot Viper II "Sector 5" 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit - PVV34G1600LLKB OCZ Gold 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit - OCZ3G1600LV4GK G.Skill RipJaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit - F3-12800CL8D-4GBRM They are all CL8 and i cant really spot a difference. Can someone please advise which to choose, or recommend another. Thanks
Windows 7 64-bit (i can use 4gb+ RAM). And I may overclock in the future after upgrading my graphics and psu, but nothing dangerously high...
I'd have a look at these: http://www.ebuyer.com/product/191175 They're CL8, 1600MHz & are only £95, which is a decent deal considering the current soaring prices of memory.
Unless anyone can tell otherwise, all your selection appear to have the same specs and are compatible with your mobo. This being the case, it's down to a combination of: price + reputation + warranty. Telltale Boy seems to have found the best offer around at the moment.
