Memory Help choosing the right flavour of memory
Discussion in 'Hardware' started by bdigital, 28 Nov 2010.
  1. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Hey all,
    Im about to change up my system to an i7 860 + Gigabyte GA-H55M-UD2H board.
    So, i need to get some DDR3, Dual channel memory.
    It just so has it that they are on Scans 'Today only' page, but there are quite a few different types of this ram, so i wondered if you guys could point out the best ones for me?
    CMX4GX3M2A1600C9 - 4GB (2x2GB) Corsair XMS3 DDR3 PC3-12800 (1600), Non-ECC Unbuffered, CAS 9-9-9-24, XMP, 1.65V
    http://www.scan.co.uk/products/4gb-...600)-non-ecc-unbuffered-cas-9-9-9-24-xmp-165v £55.41
    CMX4GX3M2A1600C8 - 4GB (2x2GB) Corsair XMS3 Classic DDR3 PC3-12800 (1600), Non-ECC Unbuffered, CAS 8-8-8-24, XMP, 1.65V
    http://www.scan.co.uk/products/4gb-...600)-non-ecc-unbuffered-cas-8-8-8-24-xmp-165v £65.94
    CMD4GX3M2A1600C9 - 4GB (2x2GB) Corsair Dominator DDR3 PC3-12800 (1600), Non-ECC Unbuffered, CAS 9-9-9-24, DHX, 1.65v
    http://www.scan.co.uk/products/4gb-...)-non-ecc-unbuffered-cas-9-9-9-24-dhx-18v(amd) £70.44
    Thank you :rock:
  2. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    #3 is for AMD chipsets, so not that one.
    #1 and #2 are practically the same, except the memory latency is better for #2.
    You're overclocking, right? Might be beneficial there, but I don't know whether #2 being CL8 as opposed to CL9 is worth £10 difference or not.
  3. Guest-16
    Guest-16 Guest
    1.
    Save your money.
    Shame we don't have Newegg in the UK tbh, you'd get far more brand choice and competition.
  4. bdigital
    10 Aug 2010
    Thanks Bindi - much appreciated. Just dug out my CPC and they also recommend the 9-9-9-24 sticks.
    Yes i will be overclocking.
    Im going to hang on and see if anything pops up in the market place over the next day or so.....Otherwise il go new
  5. Guest-16
    Guest-16 Guest
    8GB kits aren't that much money these days, if you want to spend more on something: go for that :thumb:
    $90 in the US right now :(
  6. bdigital
    10 Aug 2010
