Cooling Help Cooling
Discussion in 'Hardware' started by MarkW7, 16 Apr 2009.
  1. trig
    trig god's little mistake
    10 Aug 2006
    cant see the pic. temps below 70? which temp monitoring software was showing 90 degrees? i'd use core temp.
  2. stonedsurd
    11 Mar 2009
    I'm not trying to start a massive debate here, but try going with positive pressure (more intake, less exhaust) for the fans.
    It helped my temp + dust issues to a great degree.
  3. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Yes, below 70 now but my core speed is 1.6GHz, 200x 8multiplier just figuring out how to change it now :(.
    Thanks - Currently i have
    2 intake
    1 exhaust
    and PSU.
  4. Krikkit
    21 Jan 2003
    Is the multi like that the whole time? Checked the BIOS? Try turning speedstep off to be sure.
  5. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Yes, the multi is always at 8.
    I can't find speedstop anywere.
  6. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Post removed by user.
  7. Krikkit
    21 Jan 2003
    Speedstep should be a BIOS option.
    Try setting the multiplier manually?
  8. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
  9. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    The multiplier is stuck at 12.5
  10. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Mark - That's what it's supposed to be.
  11. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
  12. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Overclock = Multiplier x FSB. Some people like to raise their FSB to as high as possible and then raise the Multiplier until they hit the max stable overclock as it gives a slight overclock to other components as well as the CPU however the relative performance increase is so small that its rearely worth bothering lowering the Multiplier.
  13. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    So i should leabe the multiplier at 12.5 [Max] and just up the FSB?
    Thanks.
  14. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Yes. :)
