Motors Help find specific sized bolt
Discussion in 'General' started by goldstar0011, 24 Feb 2011.
  1. Xir
    Xir Modder
    26 Apr 2006
    I'm afraid it's not a normal DIN (or ISO) shape, in other words, it might be a Volkswagen special.
    DIN 609 ir DIN 610 is similar, but without the "toothed" part, also only goes till 10.9 :eyebrow:
    Actually, that would be special, readily available is 8.8
  2. Krikkit
    21 Jan 2003
    If there's 8 bolts in the kit, and disassembling them from another 'box is gonna be hard work, I'd go for the kit tbh. It doesn't sound like it's going to be sensibly simple to find them from another source.
  3. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Found out I need a 12.9 grade bolt for the gearbox
  4. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    http://www.aseriesspares.co.uk/Fast...2-9-Self-Coloured-7/16-UNF-Sets/prod_599.html
    Price is for 10 bolts - various lengths available.
    http://www.aseriesspares.co.uk/Fast...ut-Hex-Zinc-Plated-UNF-Nut-Sets/prod_258.html
    Plain nuts, to suit - you'd need to use some thread or stud lock
    http://www.loctite.co.uk:80/cps/rde...redDotUID=productfinder&redDotUID=1000000IA39
    Or use some all metal locking nuts:
    http://www.merlinmotorsport.co.uk/F.../p905/K-NUT-6-POINT-7/16UNF/product_info.html
    I'm not sure you'd want to use nylocs in the gearbox, as it's going to get hot in there.
  5. goldstar0011
    2 Sep 2007
    Thanks, will contact them to check what they got
  6. Mr.ME
    Mr.ME Minimodder
    22 Jan 2006
    long shot but ask your local seat dealer, most of the parts used are the same on vw's.
    part numbers are often the same, but price is alot cheaper.
  7. goldstar0011
    2 Sep 2007
    Thats so simple I never thought about it
  8. goldstar0011
    2 Sep 2007
    Found a helpful chap in USA who will compare the specs to a similar kit thats cheap there and let me know and also found a guy who will part ex my kit if I provide what I need.
    Getting somewhere at least
