Development Help for an absolute programming beginner (DONE)
Discussion in 'Software' started by fdbh96, 15 Jan 2012.
  1. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Well I decided today to find out a bit more about programming, and decided to start with python, as it is meant to be easy to learn, and free to develop.
    However, when writing my first program, print "Hello, World" it doesn't seem to work, and every site/book I've read doesn't explain how this might happen, as there really shouldn't be anything wrong with it. :wallbash:
    Here is what I have tried so far.
    Python 3.2.2 (default, Sep 4 2011, 09:51:08) [MSC v.1500 32 bit (Intel)] on win32
    Type "copyright", "credits" or "license()" for more information.
    >>> print "hello, world"
    SyntaxError: invalid syntax
    >>> print "hello, world
    SyntaxError: EOL while scanning string literal
    >>> print "hello, world "
    >>> print hello, world
    >>> print "hello, world'
    Thanks for any help :thumb:
    EDIT: Found out why it wasn't working, it should be print ("hello, world!)
  2. faugusztin
    11 Aug 2008
    Looking at examples, it shouldn't be this ?
    Code:
    print 'hello, world'
    Note: never programmed in python.
  3. fdbh96
    29 May 2011
    I have just downloaded Python 2.7.2 instead of 3.2 and it seems to work, any suggestions?
    EDIT: Found a solution
  4. fdbh96
    29 May 2011
    That doesn't work either :sigh:
    EDIT: found a solution
  5. faugusztin
    11 Aug 2008
    Not sure what is problem in your case then :
  6. fdbh96
    29 May 2011
    In python 3, it changes to print ("Hello, World!")
    Thanks anyway :)
