PSU help from the pros please? :')
Discussion in 'Hardware' started by LukeDaly, 9 Jun 2011.
  1. LukeDaly
    LukeDaly Pokemon Master
    9 Jun 2011
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  3. trig
    trig god's little mistake
    10 Aug 2006
    so basically, power-wise, it absolutely would run it. almost twice over...but as blogins has pointed out, if you ever upgrade your gpu situation to a dual card setup with the need for 2 pci cables each, then you would have to resort to molex to pci-e adapters, which isn't the way to go.
    if you see that as a possibility in the next couple of years, grab the hx as suggested...
  4. murraynt
    murraynt Modder
    6 Jun 2009
    Ahh shucks :blush:
    I agree with blogins. You are getting alot more PSU for 10 pounds. DO you have the two 6850 already? One single card might be better for the job and go crossfire later? Maybe somethinf like the 6950
  5. LukeDaly
    9 Jun 2011
    i havnt ordered cards yet guys :) just thought that two 6850's would be more powerful than a single 6950?
  6. LukeDaly
    9 Jun 2011
    would the two 6850's not be better than a single 6950? :O
