Electronics help getting these motors running..
Discussion in 'Modding' started by Springs, 9 Feb 2007.
  1. Springs
    Springs Boing boing
    29 Aug 2004
    need some help.. got this old r/c tank that i got ages ago and being me i took it apart after i broke it and didnt put it back together afterwards..
    anyways a lot of the wires came off and i cant easily tell what came from what.. now ive got the power working but i want to get the motors running so i can drive it around...
    anyways here is a pic of the unit..
    now ive got 4 wires i cant really identify.. one is a black stripped wire which i think comes from the resistor and then i got 2 more black wires with resistors on and a red one with a resistor on... any ideas on where they could go?
  2. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    need more detail, i cant understand what you said. can you get more pics of the wires and more detail?
  3. Freedom
    Freedom Minimodder
    27 Oct 2004
    looks like a pair of normal RC hobby motors to me they'll need to linked to some kind of speed controller. but as he said need more detail.
  4. Jipa
    5 Feb 2004
    Just put in new wires (two to each motor) and bruteforce how they must be connected to the speed controller. If this is a cheap toy, all the electronics are most likely on one PCB and you must first find the place where they should be connected and then trial'n'error which lead goes where.
    There's no change you'll blow something if you just stick them to the right place, DC-motors are controlled by just switching the + and - wire around.
  5. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    You have 4 wires, so hook those up to a battery. Just do trial and error until you find out which wires go to which motor.
  6. Springs
    Springs Boing boing
    29 Aug 2004
    thats the pcb ive named the wires..
  7. Jipa
    5 Feb 2004
    Yeah that's a piece of cake? Red and black wire to each motor and you're ready to go. Tho I bet you've messed something up because those four on the right side of the PCB look the right ones. Two reds and two blacks.
  8. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    yes, the wires connected to two power transistors (or fets? or voltage regulators?) look quite similar... The big (thickest) black wire is definitely the common ground, looking at the other wire connected to the same pad... That makes the last red wire the common V+ (and the white wire soldered to the same pad confirms that)
    The only thing you'll have to figure out by trial and error is which side of the motors should have red, and which side should have black...
    Can you show us the other side of that PCB? I'm quite interested in the components on that thing
  9. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    just looking at the back side of the PCB...
    I made my annotations in yellow,
  10. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Yep, there's no doubt the above is correct.
