Electronics Help - Glow String
Discussion in 'Modding' started by c.u.later, 6 Dec 2007.
  1. c.u.later
    c.u.later What's a Dremel?
    16 Apr 2005
    hey guys, getting a load of this stuff pretty soon, and was wondering, is there a cheap and easy way to make up a 12v circuit using batteries? looking at getting it wrapped round my mates guitars for the gig we're doing, so ideally something that can be strapped to the back, and portable.
    any ideas?
    all help appreciated,
    c.u.later
  2. jakenbake
    jakenbake full duplex
    5 Jun 2005
    8 AA batteries in series. actually, you could use AAA, AA, C, or D batteries (as long as you have 8) because they are all 1.5 volts, but different amp-hours (the bigger they are the longer they can power something).
    and for the math (brace yourself, its hard):
    8 * 1.5V = 12V
    you could also use 2 of those 6V lantern batteries in series, but they are a bit larger
    heres a website explaining the differences between connecting batteries in series and parallel: http://www.zbattery.com/seriesparallel.html
  3. dragon2309
    dragon2309 techie
    28 Jul 2006
    You can get tiny (think half a AAA size) 12v batteries, some places call them lighter battereis, some have number codes like A27 or A28 battereis. You would be changing it maybe every 15-20hours max though. Maplin Electronics sell them, i know that.
    dragon2309
  4. Cinnander
    Cinnander What's a Dremel?
    19 Apr 2007
    Doesn't EL string need a bit more than 12V? I thought they came with inverters like CCFLs do (but I should imagine don't crank the voltage up quite that high, 100V or so) :s
  5. dragon2309
    dragon2309 techie
    28 Jul 2006
    Providing he uses the inverter (he probably would) then the input is still 12v, no need to use any different for the supply voltage
  6. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    :rock: Yeah dude awesome! If you pull it off, post some pics.:rock:
  7. Cinnander
    19 Apr 2007
    Well that's the reason I was asking; sticking an invertor on the back of a guitar (which have pickups) might look great but sound a bit bad :p
    Belt clip I guess, just careful that wire doesn't come out now, or you'll be dancing too :D
  8. devenfore
    devenfore LANCandy
    8 Jul 2003
    If it's an electric guitar you could run a second cable. Maybe that isn't an option though.
  9. jgrade
    jgrade What's a Dremel?
    2 Mar 2004
    How about using phantom power from the mixer. If using a second cable or hacking one for your purpose is an option then it may work. A plus is that if you use a mic cable, it should provide enough shielding. The EL would not be very bright but should be visible. I think the best would be to shield an inverter very, very well and strap it the back of the guitarist. However, I am not sure if the frequency of the wire wrapped around the guitar would introduce any noticeable noise. I would make sure have new cables with REALLY good grounds.
    Good luck. Should be very cool if it works.
  10. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    My EL string used to interfere with my CRT, so it might be worth trying it out first.
    How about fairy lights instead :D
