HELP! harddisk problems
Discussion in 'Tech Support' started by JCG, 7 Nov 2008.
  1. JCG
    JCG What's a Dremel?
    1 Dec 2005
    I got a notebook shoved into my hands, with the words "Doesn't work, fix it" :wallbash:
    After asking some questin they crammed a new harddisk in it and it doesn't work. Ofcourse they never burned a recovery DVD of Vista, and the old hard disk is gone :wallbash:
    So I tried installing window xp (will upgrade back to a legal vista install), but it say no hard disk found.
    I look in BIOS, well the hard shows up correctly
    I tried formatting it, sadly I could only do it to fat32, but that worked. But still the install wouldn't see the hard disk.
    The notebook is a HP 530
    Does anyone know a trick to get this notebook to work?
  2. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    I'm assuming it's a SATA hard disk?
    If so, check in the BIOS to see if you can set the hard drive from AHCI to IDE mode, that might let XP see the drive.
    If not, you need to integrate the SATA drivers onto the XP CD, nLite can do this fairly easily.
  3. JCG
    1 Dec 2005
    good one, yeah it's sata. How could I forget to get the drivers. Trying that now
  4. JCG
    1 Dec 2005
    :thumb:, thanks for the advice, the laptop is running great now.
    The problem was that I forgot to add the sata drivers to the windows cd.
    well I'm of the find the rest of the drivers for the laptop
