Modding Help! How to illuminate Acrylic Sheet with LEDs
Discussion in 'Modding' started by rups22, 2 Sep 2006.
  1. rups22
    rups22 What's a Dremel?
    31 Aug 2006
    Hi
    can anyone give me some good advice on how to illuminate some perspex using 4 bright Red LEDs...for this project
    Leather Briefcase PC
    i have made a tight hole in a test piece of acrylic and shoved a green led in there...but the acrylic doesn't seem to glow...what am i doing wrong?
    Cheers
    Rupert
  2. ch424
    ch424 Design Warrior
    26 May 2004
    You have to sand down the top of the LED, to give as much diffusion as possible - and make the hole as rough as possible.
    ch424
  3. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    You won't see the light unless the acrylic is damaged like sanded or carved. It blocks transmition of light except around the edges. But come sanding patches or engravings in it and watch it glow.
  4. Skylined
    Skylined Minimodder
    3 May 2003
    As it has been said, if you want the whole acrylic to glow, sand the back part of it.
    You can also use some adhesive transparent sheets that have a texture, and put it in the back of the acrylic.
    Here's an example, what's engraved, glows, what's just acrylic, doesn't.
  5. rups22
    31 Aug 2006
    thanks!
    Cheers guys
    i'll be roughing up that acrylic ASAP!
    rupert
    :thumb: :thumb:
