Hey People this is my first every thread on this forum. Basically I'm planning to start a scratch build/ water cooled Pc in the next few weeks:dremel, for which i'll create a project log, and still cant seem to find the dimensions for the I/O Panel and power supplie. By I/O i mean the L shaped cut out by which u put ur I/O panel in and expasions slots. In addition By Power supplie dimensions I mean the dimensions and if possible the pattern of a PS mounting. If anyone could help me with this is would be extreamle greatful and it will make me planning alot easier. Anyway as i said this is my first time making a thread and HI! I also appologize if this thread is in the wrong forum lol.
Hi, you can find a vector drawing here: http://forums.bit-tech.net/showthread.php?t=194086 Here you can find the dimensions for the power supply: http://en.wikipedia.org/wiki/Power_supply_unit_(computer) found over google "power supply dimensions in the pics.
This website will show you the form factors (Dimensions and placements of parts) for the main motherboard shapes, you'll need the ATX specification v2.2 which will show you everything you need to know. Specific placement of the different IO connectors in the IO region is no defined which is why most motherboards come with their own IO plate so you'll need to use that if you don't plan on cutting your own. Final note, "you" is a three letter word containg y and o in addition to u, it's not that hard to put in the extra letters and it makes the board a nicer place and easier to read, same with "your". Also, you don't get a***holes like me picking you up on your spelling... Welcome to the forum, watch out for the thread drift. Moriquendi
Thanx for the help and advice Blooddrunken, it's really going to help me finish the last few details on my plans. I don't know how to quote your message lol so i do apologize if i'm doing this wrong. But thanx again mate. =)
Thank you Moriquendi as well, again your help will really help me finish a few bits off and I thank you a thousand fold. Also thanx for the welcome it's great to be a part of this community, although i don't know what thread drift is lol. Cheers
