HELP i want to get a AMD XP-M laotop
Discussion in 'Hardware' started by psYCHopath, 24 Sep 2003.
  1. psYCHopath
    psYCHopath What's a Dremel?
    25 Dec 2001
    http://www.twinhead.com/news/2003/20030630.htm
    Features:
    I'm a student and quite intrested in this Twinhead efie 121A.
    Dont mind bout small screen or the graphic shared memory.
    Though if i get it I will add another 256 = 352 (32 alocated for display)
    Has anyone has it?
    or any other AMD XP mobile laptop.
    What is your comments on the power consumption? How long will it last for a normal usage and playing songs with winamp?
    Thanks.
  2. Tim S
    Tim S OG
    8 Nov 2001
    the AMD's are very power hungry laptops just FYI ;)
    also
    where did you find something with such extreme speed?!?!? :p :hehe:
    kidding of course ;)
  3. HellDiver
    HellDiver What's a Dremel?
    31 Aug 2003
    Twinhead's laptops are junk. Sorry to have to tell you that.
  4. psYCHopath
    25 Dec 2001
    bigZ:
    hahaha becasue it has sort of a good price tag for its spec. As with the same amount if choose as Pentium4-M I will not get any DVD-CDRW combo. Thats the advantages
    Helldiver:
    Do you have a Twinhead laptop. :blah:
