Just picked up this Datasheet http://www.mark-products.com/pdf/g240x128/014/014 spec.pdf but i need negative voltage for the contrast so would this do the job? http://custom1.farnell.com/cpc/prod...C-DC+Converters+-+PCB+Mount&product_id=263630 PW0005066 6th one down 5v to -15v and while i have your attention, will i need the particular cathode inverter it recommends or will i get away with using a regular inverter ? Thanks in advance
nope -12 is not going to do it, needs about -15 just wanted to make sure that dc converter was going to do the job, should do mmmm lol
bump.. Would still like any info, will i need a special inverter or will i regular CC inverter do ? cheers guys
