Cooling Help! Looking for a watercooling part
Discussion in 'Hardware' started by scopEDog, 12 Apr 2002.
  1. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Hey guys! I'm in the process of finishing my h20 setup but I'm stuck at one part. My airtrap and radiator are outside of the case, and my pump is inside. I wanted to find a way to connect the hoses from the inside and outside. Some type of coupler to connect 2 barbs together, and it needs to be mountable (I'm looking for a "clean" look, i don't just want to drill a hole in my case and glue the coupler in the hole). Does anybody have an idea on how to do this? Maybe someone knows of a part like this?
  2. Chrisy
    Chrisy What's a Dremel?
    27 Jul 2001
    I think the thing you are looking for is a bulkhead connector. They have them over on Norgren part number 34002107 sould be something like. You will also need the correct barbs to connect to it for your pipe size.
    Chrisy
  3. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Thanks for the tip! Seems like they dont have it though :( (They have one end push-in and other is 1/8th barb) Looks
    like this is a tough thing to find, guess I'll keep searching..
