Displays Help me choose a new 20" TFT
Discussion in 'Hardware' started by Koolpc, 10 Aug 2008.
  1. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    I am after a new TFT to replace my 17" one. Ideally looking for a 20" TFT. I want it to be good quality, have DVI and black. I have seen the DEll ones and these 2 take my fancy:
    Dell E207WFP 20-inch widescreen &
    Dell UltraSharp 1908WFP 19-inch Widescreen
    I know the 1908WFP is a 19" but if people say it is a better TFT then i don't mind losing an inch!! I have also seen this one mentioned:
    21.6" Hanns G HG216DP (I know it is not black but looks nice anyway)
    Not sure which would be the best. The 3 above are around the price that i can afford. If anyone has one or can advise then i would be most happy.
  2. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    NEC 20WGX2 fothawin. 20" Wide. S-IPS. Not black, but hey.
  3. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    i think you would be pretty happy with something from the samsung range, i sure am with mine
  4. JamesCreese
    JamesCreese What's a Dremel?
    10 Aug 2008
    unimpressed with my E207WFP (next to my 2007WFP) if you can get a 2007WFP I'd recommend one of those, the E207WFP is a little over exposed imo
  5. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    How do you mean?
  6. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    Scrap the above TFT's!! Seen some bad reviews of them!!
  7. GregTheRotter
    9 Aug 2008
    heh, more like the one I suggested is just over your budget and wasn't 'just' released.
    review of NEC 20WGX2;
    http://www.behardware.com/articles/610-1/nec-20wgx-an-ips-equivalent-to-a-2-ms-tn.html
    BenQ FP222W H
    http://www.custompc.co.uk/reviews/149454/benq-fp222w-h.html
    Samsung SyncMaster 2232BW
    Samsung SyncMaster 226BW
    TBH, if you've got the those Dell one's in mind get those...
    Oh and yeah, I know I haven't reccomended ONLY 20" monitors. 20"ers really aren't the rave at the moment. 22"ers and 24"ers are become more popular.
  8. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Read this.
    It's a pretty comprehensive guide, helped me.
  9. sjhujh
    sjhujh Minimodder
    1 Feb 2008
    Samsung 2032MW, great screen....
  10. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    And over my budget!
  11. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    Anyone else?
  12. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    :confused: It's available for £199.99 (delivered) from Play :idea:
    Alternatively... Samsung SM2043NW(X) (black) / Samsung SM205BW (silver)?
    But does it absolutely have to be a 20" screen, 'coz £200 can get you the 22" Samsung 226BW... and the 22" version of the a/m screen (SM2232BW) for just £182.50?
  13. sjhujh
    sjhujh Minimodder
    1 Feb 2008
    What is your budget? is 170 ish you max? or can you stretch 20 quid more
  14. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    £170 is absolute max mate
  15. caffin999
    caffin999 Bit of a noob, but learning quickly
    20 Jun 2008
    samsung 2032bw! fits your budget and i've had no probs with mine. really nice monitor
  16. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    Will look that one up now. Thanks
  17. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I have a 19" Hanns-G which I love to bits so I'd recommend them as a manufacturer although I haven't had much experience with monitors.
    EDIT: It also looks pretty nice. One problem is that mine came with a VGA cable as opposed to DVI but It has a DVI connector as well (just no cable included). Also mine's a different model to the 21.6" as in it looks completely different.
  18. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    So hard to find a nice 20" TFT that has good reviews. I really like the look of the Dell's i have mentioned above. The reviews at Dell are good though. Not sure if i should just 'Go for it' and get the dell 20" above?
  19. caffin999
    20 Jun 2008
    if its got good reviews and in your price range go for it!
  20. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    i have a Dell 2007WFP with an SPIPS panel.... get one, they're amazing for the price.
