Cases Help me choose CM 690 II Plus or Xigmatek Utgard-X
Discussion in 'Hardware' started by Cateye, 21 Feb 2011.
Cooler Master 690II Plus or Xigmatek Utgard-X
  1. Cooler Master 690II Plus
    78.1%
  2. Xigmatek Utgard-X
    21.9%
  1. Cateye
    Cateye New Member
    4 Nov 2007
    I have a limited budget & i am confused between CM 690 II Plus & Xigmatek Utgard-X should i go for CM or Xigmatek???
    I want a case with cable management feature, must support Long and big VGA cards/CPU coolers
    thought should ask you guys since you people are more into modding ....
  2. lamboman
    lamboman New Member
    25 Jul 2006
    I'm not going to vote, merely say, choose which one you prefer personally. Both are good cases that are fairly evenly matched when it comes to their feature set. The CM690-II's cooling at stock isn't brilliant, so you might want to buy some aftermarket fans for it, but after that, it is great. Extremely well built, good looking, and easy to work on. I'm not saying, however, that the Xigmatek is worse; I've only worked on the CM-690 models and have heard the Xigmateks are great.
    When it comes to CM690-II threads, I always like to leave a picture of the build I did, merely because it shows how many holes and areas you can hide cables in: [​IMG]
    You'd get similar results with the Xigmatek too.
  3. Uxon
    Uxon Member
    14 Dec 2010
    Got a HAF 922 here, I'm more of a fan of CM cases. :) (so my vote goes to the 690 II)
  4. KidMod-Southpaw
    28 Sep 2010
  5. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    Guess what i voted for!
  6. shadow_boxer
    shadow_boxer Member
    22 Jan 2011
    Both case look like they would perform pretty similarly.
    I've got the original CM690 Dominator Pure Black and its a cracking case. Can't fault it.
    Runs everything nice and cool, good airflow, admittedly with a fair few aftermarket 120mm fans and fan controller too.
    Case decision is 90% is down to personal preference and what you like the look of aesthetically.
  7. shadow_boxer
    shadow_boxer Member
    22 Jan 2011
    Voted for the CM 690
  8. techhead
    techhead Member
    17 Jul 2010
    cm 690 II a very nice case to work with .
  9. Cateye
    Cateye New Member
    4 Nov 2007
    CM 690 II Plus it is...
  10. alleyne
    alleyne New Member
    11 Sep 2007
    I have the CM 690 II Plus and its a great case, was awesome to work with.
  11. asteldian
    asteldian Member
    13 Jan 2011
    CM 690 II is a great case. But when I was building my PC I was on a tight budget and personally felt theprice was too steep.
    I went with a HAF 912+ and am happy I did:
    The cable management is good with plenty of space to hide the wires behind the backplate
    The backplate has a nice big window so if you need to change a cooler you don't need to take the whole thing out.
    It is very wide so can fit pretty much any CPU cooler in it
    If you remove the extra HDD case inside you can easily fit the largest GPU inside (this may be possible without removing it? I don't know as I removed it simply because it was no use to me
    It feels very solid as opposed to chea cases that have real flimsy side panels
    For £57.44 it had a lot of good stuff, in fact everything I was looking for at a cheaper price (especially as it is often on offer at Scans Today Only Deals)
    The Xigamatek looks pretty good to and a similar price, so I vote for it if your choice is just the CM 690 and the Xig. When on a budget you don't need to spend more when the Xig and HAF can offer all you need
  12. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    used both... both work great
    Its just down to your own pref RE: the look of it
    Use the CM in my office for basic air cooled work station
    used the Utgard on a small water cooled Xfire 775 socket pc build which i gave to a lovely family, that was a nice little build even though I say it myself lol.. sprayed the rads Lambo Orange to match the internals & fans lol..
    Oh sod it I liked the Utgard better for that reason alone ..
  13. murraynt
    murraynt Well-Known Member
    6 Jun 2009
    I'm going to give my vote to the Xigmatek Utgard-X(with a side window).
  14. meandmymouth
    meandmymouth Well-Known Member
    15 Sep 2009
    The 690 is just lovely and so easy to build in!
  15. Dopeyman
    Dopeyman Member
    10 Jan 2011
    I've got the utgard and love it loads of space inside for my frio. Got a 560 and still lots of space for a bigger card. Cable management is good. Also it looks great! Only problem is the fan controllers are rubbish!
  16. Apocalypso
    Apocalypso Fully armed and operational.
    15 Sep 2007
    Voted for the CM 690 II mainly because you can fit two 120.2 rads internally with no modding whatsoever.
    Worth considering if you're so inclined.
  17. red4our
    red4our ¿Qué es un Dremel?
    13 Jan 2011
    :thumb: CM690 II. Great case to work with. Solid build, nice features and easy to route and tidy up the cabling
