Motors Help me find a car battery!
Discussion in 'General' started by Wakka, 4 Jan 2020.
  1. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Short and sweet - multimeter confirmed dead cell(s) in car battery (10v reading...), so I need a replacement... Issue is, every website that I use the "insert registration and we'll find the right batteries!" feature brings up batteries with a length of 242mm, whereas the one currently fitted (OEM Exide EFB) is a 207mm unit. And the housing definitely won't fit an extra 35mm...
    Specs for current battery are:
    207x175x190mm
    55Ah
    450A
    Start/Stop (presuming EFB, but just says "stop & start")
    Go, But-Tech, go!!
  2. RedFlames
    23 Apr 2009
  3. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    I bought our last battery there, a high quality Varta one for less money delivered, than the "cheap" battery from the local National Tyres branch (was a bit skint) , that struggled in cold weather after just 3 years.
  4. legoman
    legoman breaker of things
    28 Feb 2010
    What type is it? Like in my car I have a type 096. makes it far easier
  5. Wakka
    23 Feb 2017
    That seems to tick all the boxes, and it isn't the £240+ that the Bosch alternative seems to go for either, which is another huge plus.
    Less than £100 all in inc. delivery before 10am Tuesday. Hopefully this is all I need to fork out to get it up and running again!
