Ok so I need to replace the VGA input on a projector. I need to get one from RS componants but for the life of me I can't work out which one I need. It needs to be PCB mount and it needs to be female of course. I'm lost in the RS order codes and descriptions. I don't want to end up with a 2 row 15 pin Dsub connector!! any help please?! Thanks J
Sorry it needs to mount directly to the pcb. not at rightangles. and pref RS as they are cheaper and I need other things from them too! thanks. J
The socket itself is broken? That seems pretty unusual (compared to broken traces / solder joints)...
Yea looks like the connector itself might be broken, have looked at solder traces, but doesn't look like that is a problem. Thanks for the part number, never thought I would be able to find that! J
