Hi y'all.... this is my first post ....Hope somebody can help...... This is my Yeong Yang cube case nearly already to go.... but i'm not sure how to finish it off...... I'm not worried about lighting, blow-holes etc.... as the case is going into a desk when it arrives...... I've seen the Wet and Chilly Chips 1meter pasive res which I could mount horizontally external to my case, this could sit behind my desk which'll be 1.5 meters long....... I'd rather not to put a rad/res in my case as drilling cutting is my worst nightmare..... Anybody got any ideas on how to finish this case off...... My set up is XP 2500 hopefully gonna be overclocked to a 3200 maybe the pump could go on this side maybe I could mount a 350mm pasive rad/res on top..... please help....... cheers chicken george
I think you should move the pump to the other side to tidy it up and improve airflow to the video card. In its place you could put in the front intake fan. Also give it a cool paint job and a few lights. Good luck!
i'm not worried about paint jobs and lighting..... just need to know what i can achieve with what i've got....i could move the pump to the other side and put the 120mm fan in......but it'll mean putting the tubing over the top of the dividing wall...... this could case air lock problems........ I'm really thinking about this passive rad/res........ basically like the zalman reserator thingy....... but between 300mm and 1 meter long.......... chicken george
That looks pretty good for only $98 dollars (US). It would look really sweet if you mounted it across the top of the case. But like i said before make sure it will operate while mounted horizontally.
..... yeah it does mount..... horizontally....... 350mm from overclockers.co.uk would fit on the top sorry it's crap drawing on top but a laptop touch pad it nails to draw with.....
I'd make sure the tubing would fit easily. I have the same case and I am watercooling it also. With the lines hooked up I have problems shutting the door without shoving to block back on the chip/board. I've heard that passive res doesn't work that well. Most don't, unless you have a fan or ac blowing on it.
The WACC res is a great idea. A friend of mine did that to his in process mod. Take a look, might give you some ideas/ help you out http://wetandchillychips.co.uk/phpBB2/viewtopic.php?t=939
Hi, Thanks for all you replies, I got a 90.1 thermochill rad and fixed it to the bottom hard drive fan mount...... I might add another 120.1 rad later but i wonna see how the WACC res goes.... Just arrived today.... might fix it like leeums budy and drill two holes just the right size for the barbs to go through...... like this from johnny's li-lan just hope i don't cock it up........ i'll post back when i'm done........ got some home diy to finish first
