Planning Help me settle an argument with my other half
Discussion in 'Modding' started by darth_passy, 4 May 2009.
  1. darth_passy
    darth_passy What's a Dremel?
    24 Apr 2009
    ok, I'm a massive Liverpool FC fan and wanted to have that as a theme for my first build, i wanted the case to be red and white (i have a rough idea in my head). however this is where problems started with my other half, she's a Chelsea fan and wants me to incorporate Chelsea into the theme as well. now, don't get me wrong, spiderman and superman pull it off all the time......but red and blue paint on a case......can it actually look good?
  2. Guest-2867
    Guest-2867 Guest
    NO! *slap*
  3. darth_passy
    24 Apr 2009
    well thats what i thought, i mean red and white would look awesome, but not blue, never blue. gonna have to think of a new theme then
  4. Guest-2867
    Guest-2867 Guest
    It would just turn out like some ******* child of too many ideas - If she want's a chelsea one why don't you offer to mod her PC too ?
  5. darth_passy
    24 Apr 2009
    because all she has is a laptop, this would basically be a pc for both of us
  6. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Is it going to be watercooled?
    If so, pop a plastic chelsea badge in the reservoir. Next step would be to label the reservoir with something like "Drown chelsea, drown!"
  7. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    A nice way to give the build an authentic Liverpool effect, would be to burn the case and leave it on bricks:dremel:
  8. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    Kill Her.
    Sorted.
    Red White and Blue dont work? Your forgetting the Union Jack you unpatriotic ****
    Kidding :p
  9. darth_passy
    24 Apr 2009
    look i havent opened this to cause any slangging matches, theres nothing wrong with either Liverpool or Chelsea or any football club (except Man Utd of course). all i wanted was advice on potential theme. never mind
  10. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Lmao +1
  11. Stormwulf
    Stormwulf A mod to far?
    5 Mar 2009
    Honestly think its best to use Liverpool theme on pc and just skin the laptop in Chelsea theme.
    Yes, i'm a Liverpool fan but my thinking is that you said your partner predominantly uses the laptop so it stands to reason that that should have the Chelsea theme.
    Good luck whatever you decide.
    mvagusta likes this.
  12. m0o0oeh
    m0o0oeh Minimodder
    20 Dec 2006
    There are a couple of options. You can smile nicely at a vinyl wrap specialist who usually does cars and see if they would be interested in the project, or you could do something similar to this
  13. Mr.ME
    Mr.ME Minimodder
    22 Jan 2006
    how about fading the 2 colors, bottom blue fading in to red an the top, and some white details like leds/fans...
