Linux Help me
Discussion in 'Software' started by Fowler, 18 Feb 2003.
  1. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    Ok I have partition magic 8 and I want to dual boot my system so I can have red hat on the system too,
    Am I right in saying that I need a fat partition for the linux o/s?
    Im running xp and am wondering how this all works to be honest!
    can anyone explain?
    Thanks
    :D
  2. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    no, you just need what it calls a Linux Partition, and a linux swap partititon :)
    you dont need FAT for linux, however if your doing redhat there is a partitioner in the installer i beliv, so you may as well use that :)
  3. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    One more q, what about the versions, should I get red hat 8 or not? Is 7.3 ok to use?
    :blah:
  4. Bogomip
    15 Jun 2002
    i use 7.3 :) dunno about 8.0 but 7.3 is alright, just got an outdated KDE and bits n bobs on it :) but i tihnk there easy enough to update (if you have your internet working, grrrrrr)
    :) hope this helps!
  5. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    Im maybe thinking Madrake 9.0 as I have the download edition on DVD, do u know if this will partition your hdd for u as red hat does?
    Il also have to set my bios to boot from it, :blah: !
  6. Bogomip
    15 Jun 2002
    pah, setting your bios is piddly compared to installing linux :)
    the mandrake installer will partition it oo, thoughi found mandrake less user friendly!
  7. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    So does this mean if I install madrake and the disk is partitoned, next time I switch on I will have the choice to choose from xp or mandrake linux?
    or will one load by default?
  8. Bogomip
    15 Jun 2002
    you "should" have the choice :)
  9. Hiren
    Hiren mind control Moderator
    15 May 2002
    I tried the exact same thing as you PublicNME with Mandrake 9 the installer for some reason wouldn't let me create a partition saying there wasn't enough space (I had 55gb free).
  10. Sp!
    Sp! Minimodder
    6 Dec 2002
    I may be wrong but from what I've read by free space it means unpartitioned space.... not free space on an NTFS (or FAT) partition
