My Samsung 172V TFT has started to flicker slightly? I havnt done anything to it and the other screen on my dual setup is fine. I've had it a few years and its been used daily since, do i need a knew one? I;ve unplugged and re-plugged everything. Its not a huge flicker and is more visable on dark colours. Any ideas? Mike (sorry if wrong section)
tried degaussing? Could just be a static build up? Also check no pins are bent or loose on the cables.
It's an LCD It sounds like the backlight might be on its way out - luckily, they're relatively cheap to replace. It's also possible that there's a loose connection; replace the power cable and check it's all secure.
It does sound to me like a backlight dying, but this is good in that it doesn't mean you have to buy a new screen.
