Help! Need help with Dell recovery
Discussion in 'Tech Support' started by b16ad, 5 Dec 2008.
  1. b16ad
    b16ad What's a Dremel?
    5 Dec 2008
    can any:waah:one tell me how to do a destructive recovery on a dell latitude d600 please
  2. rito
    rito What's a Dremel?
    19 Sep 2007
    did you drop the hard drive?
  3. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    What is a "destructive recovery"? Do you mean you need to recover files from a dead hard drive, or do you mean you wan to destruct all data in there permanently?
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's the one that formats the drive first, rather than a repair recovery. Try pressing F10 at boot. Or this miay work
  5. Senny
    Senny What's a Dremel?
    20 May 2008
    F12 on the D600's will get you to the boot menu, select the cd option from there and yer good to go. Never heard of the CTRL+F11 option, might be an option on the Inspiron/Vostro/Studio lines rather than the business laptops.
