Cooling HELP NEEDED!: Crazy temps on WC - STILL PROBS!
Discussion in 'Hardware' started by benje, 2 Aug 2004.
  1. benje
    benje What's a Dremel?
    4 Feb 2002
    Thing is tho olv
    The CPU is back idle at 49'c atm, after being on a few hours.
    However I have overclocked the system a little,
    The FSB is upto 180mhz and multiplier 11.5
    (previously 133x15)
    This means that the cpu is only 83mhz faster than before at default, which wouldnt suggest an increase of like 3-4'C temp.
  2. olv
    olv he's so bright
    23 Sep 2002
    What are your temps immediately after you turn it on after being turned off all night?
  3. benje
    4 Feb 2002
    Ussually in bios about 47-48.
    OK still got a problem.
    Same setup as before, but MBM is reading god-damned 56'C IDLE!!!
    My pc has only been on a few hours, i dont know what the hell is going on.
    Can anyone else offer any advice please?
  4. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    Thats when its straight from cold? looks like your well over, about 22°C over...
    so thats 34°C idle which seems correct...
    'doc
  5. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    I'm sorry to see you're still having grief with this mate but I really don't think you can trust the readings you're getting from the onboard probes at all!
    Any chance of getting a cheap thin thermal sensor and sliding it between the water block and the CPU die? That'll get you closer than you're getting at the moment.
    Is everything stable then stress testing? What are the max temps underload
  6. Murdoc
    25 Jul 2003
    £5 from mappers I think, well worth it....I need one come to think of it :p
    PS get on MSN jsj :p
    'doc
  7. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    I'd totally agree that your temperature "reading" is high but you seemed to answer you own question when you said prior to fitting a new motherboard you temperatures where around the 30c mark.
    Backed up further more as you have tried emulating the exact same water configuration as you had prior to the new board which would/should in theory give the exact same temp (providing you have mounted the block correctly) as before which leaves no other alternative................its the new motherboard!
    BTW i wouldn't suggest you put anything in between the CPU core and the water block as that would surely result in the core not making good contact with the block and could even result in chipping the core edges should the block not be flush :worried:
    VERY BAD IDEA
  8. benje
    4 Feb 2002
    Yea i totally agree with you guys, i need a temp probe, and putting the temp sensor on the cpu die will be a very bad idea. But i know ive asked this before, but where can i put it?? I mean if i attached it to the surrounding area of the bottom of my waterblock it wont be very accurate cpu reading i dont think. hmm
  9. jetsetjimbo
    19 Feb 2003
    I didn't say directly on the top of the core :rolleyes: just in the gap created by the raised core between the ceramic/wafer and the waterblock...
    Just get the tip of the sensor as close to the core as possible when insterted in the gap.
    Not the best example maybe, but...
  10. noobidoo
    noobidoo What's a Dremel?
    8 Jun 2004
    loop pump>rad>res>block
    how is this flov
  11. jetsetjimbo
    19 Feb 2003
    If you read back through the thread you'll see he's ascertained that the order of components in the loop isn't the issue ;)
  12. Etacovda
    Etacovda What's a Dremel?
    4 Nov 2003
    Try your old overclock. If its stable etc, and passes prime, then dont worry about the onboard sensors.
    I can reboot, and my NF7's temps will read 10 degrees lower.
    They're not accurate, mhz are much more accurate ;)
    http://www.overclockers.com/articles1088/index.asp Could be of interest
    Coolermeister - thats one chipped cpu! does it still work :D?
  13. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Here's an option to try but you might not like it. Personally i'd take everything out and run it on the desk just to eliminate the case temp from your issue. What thermal paste are you using? If it's generic some Ceramiqué would go down nicely. There could be no problem at all and your radiator is letting you down, personally the rad would be my second priority for buying a WC setup as it takes the heat out the water. Perhaps adding a Singe or Dual Heatercore with shroud to your setup will sort the temps out, although i'll have to admit your temps are high. As for putting a probe on i'd thermal tape it under the CPU and thread the wires between the CPU pins.
    Good Luck
  14. ferm
    ferm What's a Dremel?
    12 Aug 2004
    When you first put all th eliquids you see tha flowing normal or going slowly to the tubes ? Maybe rad is not moving the water normal or the pump not runing full ?
