Windows Help needed please winspm.exe
Discussion in 'Software' started by Kovoet, 16 Apr 2013.
  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Hi guys I am getting this error every time I close down my system. When it's up and running there are no issues that I know of. Please help me and has anyone else had this issue.
  2. workingclass
    workingclass What's a Dremel?
    17 May 2010
    Think you need to be more specific, in as to the nature of your error. A quick search on google lists some results, some suspicious others not as much. As far is I can tell this would be related to some sort of networking tool developed by some company named Avaya, although I've never heard of them. What have you done yourself to figure out a solution to your problem? Google seems knowledgable about it...
    Your best bet would be to uninstall said tool, and if you need to re-install. I'd advise you to download autoruns and see what this .exe is related to and disable it if you don't already know, and then possibly use CCleaner to clean things up. If you are not aware of any program this file is related to then search your computer for the folder its in, and remove the program related to that folder, preferably through an uninstall of some sort. If you are having problems finding the file, in that its not actually on your system, use autoruns to disable anything with this filename attached to it and related programs and you should be good.
