Other Help needed to find a cable
Discussion in 'Hardware' started by plymgary, 16 Mar 2009.
  1. plymgary
    plymgary New Member
    16 Mar 2009
    Hi everyone,
    I am trying to set up VOIP by connecting my USB phone directly to my router. The thing is, I am having problems locating a RJ45 Male Ethnet ------> USB (Type A) Male connection cable.
    I thought this being a tech forum someone might have an idea of where one could be found. If so, can you point me in the right direction??
    Many thanks,
    Gary :)
  2. heir flick
    heir flick Active Member
    2 Feb 2007
    if your in the uk then i found maplins very good for finding odd connections
  3. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    i really really doubt that that is going to work. the reason they don't make cables like that is because they are two totally different protocols, and you can't just plug one into the other.
    Krikkit likes this.
  4. Krikkit
    21 Jan 2003
    Quite.
    Some routers do have purpose-done USB/RJ11 ports on the back for VOIP phones, but USB->RJ45 just won't work tbh.
